1997 2.5 diesel exhaust front pipe fitting
Postby Transvestite » Thu Nov 24, 2005 12:18 pm
How easy is it to get to the bolts that hold the front pipe to the manifold? Looks impossible!
Just weighing up whether it's worth replacing or if I just bodge fix the split...
Transvestite
Postby madmark » Thu Nov 24, 2005 1:01 pm
i dont think they are to bad to do,but the bracket on the gearbox crossmember is a pain! :?
Postby jay » Fri Nov 25, 2005 4:41 pm
if its got 2 downpipes reasonably easy as long as bolts/nuts not to rusted.wd40 helps.undo them from underneath with a long extension on the ratchet may help to get someone to guide the socket onto the nuts/bolts.and also to help when refitting and putting the nuts on finger tight.good luck its bloody cold outside so wrap up.
mk1 connect tourneo
jay
76ps exhaust
Postby john leeman » Fri Nov 25, 2005 9:55 pm
Done this job many times, get at them bolts from under passenger door double extension 3/8 drive with a deep socket,guide with one hand & hold retchet with other, good luck.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Postby Transvestite » Mon Nov 28, 2005 2:04 am
Thanks lads! Looks like moving the airbox out the way and getting another pair of guiding hands should help things...
The Transitparts dude off ebay is selling a new genuine front pipe for £60, I'll think I'll go with that, unless there's anywhere that is a cheaper Transit parts shrine??
Cheers!
Transvestite
