Heater temp control
Heater temp control
Postby rallyevo3 » Sun Nov 27, 2005 6:21 pm
My heater temp control was very stiff on the mk5... so being an idiot I forced it with pliers and now it's kna*****ed... I managed to find the control on the heater box (like I should have done in the first place) and operated it manually... it is not stiff so the problem must be with the dial.... well it is now for sure... how do you get the dials out to correct this stupid error? :oops:
rallyevo3
Postby MrMPuk » Sun Nov 27, 2005 6:57 pm
The dial is a rack and pinion, if you take the section out where the stereo is it's quite easy to see.
