Bloweing Exhaust
Bloweing Exhaust
Postby Aztran » Mon Nov 28, 2005 10:03 am
Marnin,
My vans exhaust has developed a hole toward the front of the exhaust system, its the gauze type bit, pretty much below the gear box, its about 15 inches long.
Can this bit be replaced or do i have to get he whole section from the engine to there? :cry:
Azza
2000 x, new style Transit 350!
Aztran
Postby FredTransit » Mon Nov 28, 2005 11:05 am
As long as it's not a V6, most parts are available off the shelf. It depends what you want to spend. If you are keeping the van take it in and see what needs doing, make your mind up then. If you are selling it, bodge it up with gun gum or an exaust bandage (if it will work where the hole is) and get rid sharpish. Remember it doesn't have to be pretty (as long as it's legal).
FredTransit
Mk2 Trannyist
Postby MrMPuk » Mon Nov 28, 2005 11:13 am
Any clues on what year and eninge might make life a little easier!
Postby madmark » Mon Nov 28, 2005 11:55 am
you will have to get the hole downpipe replaced! :(
Postby Valsheda » Mon Nov 28, 2005 12:11 pm
OUCH , THE MOST EXPENSIVE BIT ASWELL :(
Valsheda
Top Tourneo Owner
Postby jay » Mon Nov 28, 2005 4:59 pm
If the bit is fexible then u can get the flexi bit and weld it to your exhaust.but a new front pipe is not to dear!!and do you really want to do welding this time of the year..only 5 bolts to undo to take the pipe off.cant really patch it as it moves..
mk1 connect tourneo
jay
Postby Valsheda » Mon Nov 28, 2005 5:07 pm
GUESS I WAS THINKING ABOUT THE QUOTE I GOT FOR MINE BUT FORGOT MINE HAS A CAT ON IT WHICH WILL MAKE IT MORE £££££
Valsheda
Top Tourneo Owner
Postby MrMPuk » Mon Nov 28, 2005 5:13 pm
Who says he hasn't got a cat! Don't even know what van he's got!
Postby jay » Mon Nov 28, 2005 5:40 pm
looked in previouse posts by aztran and he got a 1995 190 2.5 di.if its a 70hp its got 1 downpipewith no cat is 823.807
a 76 hp its got a twin down pipe with no cat 823.359
a 70 hp with a cat only 1 downpipe 823.827
6 figure numbers are bosal numbers.look in book or web site for pics of the exhaust.cross match with what ever pipe you may think of getting.
mk1 connect tourneo
jay
Postby Aztran » Tue Nov 29, 2005 9:54 am
Cheers for the info.............................wanna get it done soon as i suppose so it dont fall off sum place
Aztran
Postby Aztran » Wed Nov 30, 2005 12:07 pm
Anyone know a rough estimate on the price to look for :oops:
Aztran
Postby Aztran » Tue Dec 06, 2005 4:37 pm
Got it done yesterday.......£112 inc vat. Not a bad price i thought.........
Aztran
Postby Gunslinger » Tue Dec 06, 2005 4:51 pm
i've never liked those flexi joints, always find that manufacturers always always seem to use any old crap for exhausts and dont give a crap how easily they fall apart.
i will be building my own for mine, and it will exit out via the side infront of the rear wheels and wont be running so dam close to the prop or centre bearing as it does normally, other than that i will use the standard 2 box config and spacing so should i really have to replace it later with new standard ford boxes they will fit right in nice and easy :) ... one of the boxes going in there now is a straight through stainless steel box :P
Gunslinger
