by stevew » Fri Nov 25, 2005 11:44 pm
Rallyevo3:
Sounds like you've just got the simple hotter/colder control. What does the timer look like behind the seat? The heater will have some sort of control box with it but this is all automatic and not for user control. What do you mean by chattering? If the relay keeps clicking then it sounds like there's not enough voltage getting to it. The heater requires a large current (20A) to start as it has a glow plug in it. If you have a dodgy connection or too thinner wire the voltage at the heater will drop when it tries to start causing the relay to turn back off. Try it with the engine running as you then have a slightly higher voltage. Of course I don't actually have a Webasto heater
but I have an Eberspacher and they're supposed to be very similar. Eberspacher provide all their manuals for download but I can't find any for Webasto.
Mark:
What do you mean by grease? Actually grease or is this some slang term for underseal?
Steve
Van Cam, service suspended (no van!) (no cam either!)
