by GMC » Thu Dec 08, 2005 11:45 pm
I recently had an identical sounding noise in my tranny after changing the clutch (and release bearing).
Turned out to be the bearing alighnment. It was not sitting squarely on the main shaft or the clutch lever fork. I was when it was fitted on the garage floor, but think it got knock when aligning the box and engine during refitting.
Don't panic though, if can be sorted without removing the box again.
There is a big 'rubber blank' on the n/s bell housing (it's on the o/s if your tranny's a left-hand drive!).
Remove the rubber blank, and with the help of a small torch, look inside. The hole is big enough to put your hand into, and realign as required.
Hope this sorts yours, it did mine !
