wheel nut size help
wheel nut size help
Postby Gunslinger » Tue Dec 06, 2005 2:56 pm
does anyone have any idea if these will fit my 1984 lwb mk2 ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=4595582643&ssPageName=STRK:MEWA:IT
Basically, at what point did ford change wheel nut sizes and what were they before and after, i know that 94 twin rear wheelers have a different style of wheel nut than mine and the n/s are not left hand threads ... thats about as far as my knowledge goes with wheel nuts :P
Gunslinger
Postby madmark » Tue Dec 06, 2005 3:28 pm
on the twin wheelers i allways use a 24mm socket if that helps! :?
Postby Nighthawk » Tue Dec 06, 2005 3:42 pm
Early tranny's had 2 different wheel nuts depending on the size of the vehicle.
as a quick rule, 5 studs on single wheels were 19mm (3/4") and 6 studs twin wheels were 24mm (15/16")
in about 91 with the introduction of the 92 model and the N/S nuts became right hand threaded. a 19mm nut was still used on 5 stud wheels.
Now current Transit uses a 21mm socket on everything
Nighthawk
Postby Gunslinger » Tue Dec 06, 2005 3:46 pm
ahhh .... thanks for the info, guess they wont fit then :(
Gunslinger
Postby MrMPuk » Tue Dec 06, 2005 3:55 pm
Any truck parts place will be able to sell you some to fit, they are only pennies each to!
Postby Gunslinger » Tue Dec 06, 2005 4:08 pm
ok, cheers :) i'll take a look around
Gunslinger
