Heater Problems
Heater Problems
Postby Aragorn » Wed Dec 14, 2005 2:04 am
Ive got no blower on my mk5. ive checked the fuses and cant seem to find any relays so i can only imagine there is something wrong with the blower itself?
it doesnt work on any setting...
does the dash need to come out to get into it? can u get at the wiring to ensure the fan motor is getting power before ripping the entire dash apart?
cheers
Aragorn
Postby rallyevo3 » Wed Dec 14, 2005 10:15 am
All I know is that if it's the resister behind the headlamp it usually runs on speed 3, and you can see more with the radio out... I have a wiring diagram but would have to email that as posting it on the forum doesn't work..
Ian
rallyevo3
Postby 100ps_drw_hicube » Wed Dec 14, 2005 11:14 am
check the resistor first these always go also quite often the wiring burns out usually near the back of the switch
100ps_drw_hicube
Transit Abuser!!
Postby Aragorn » Wed Dec 14, 2005 12:25 pm
i have a haynes manual with the wiring diagrams in so thats not a problem, i'll try n get the switch out and check the wiring on it,
and i'll have a look at the resistor behind the headlight
Aragorn
Postby MrMPuk » Wed Dec 14, 2005 12:32 pm
If the resistor goes you only lose speed 1 and 2.
Postby rallyevo3 » Wed Dec 14, 2005 12:36 pm
I said that :lol:
rallyevo3
Postby MrMPuk » Wed Dec 14, 2005 12:41 pm
Yeah but he said he was going to have a look at it so was making sure!
Postby gemini » Wed Dec 14, 2005 1:13 pm
thats not strictly true, my mates heater only worked on no3 for since he bought the van, then it stopped working altogether, he fitted a new resistor and it works now on 1 2 & 3
mines only working atm on 1 & 3, i have got a resistor but havent fitted it yet, i'm hoping it cures it
gemini
Postby Aragorn » Wed Dec 14, 2005 3:05 pm
ok update
i removed the plug from the blower and tested for voltage, nothing
so i replaced that and got the wiring diagram out for the wiring to switch and connected the 12v feed to the blower output and bingo, big spark and blower fires up
tried the 12v feed to one of the resistor outputs and got nothing
so i popped the bonnet and had a look for the resistor, and found a horrible rusted old lump of crap, it was that bad the 3 spade terminals just snapped off it when i prodded it.
i can only imagine the resistor has shorted out to the chassis and the switch has blown (one of the contacts on the switch plug was melted), i made a bypass to allow me to get full speed by connecting the 2 terminals to a rocker switch however the connections on the switch block arent very secure and i was a bit worried that they'd fall off once i started driving around so i removed it and will have to find another switch and a resistor pack
also noticed that after about 20-30secs of running the fan starts to make a kinda screechy noise which probably means the motor IS going to pack up anyway :roll:
Aragorn
Postby FredTransit » Wed Dec 14, 2005 3:10 pm
The screeching niose is completely normal on the transit, we have had one doing it for more than 10 years, so I wouldn't say it's about to pack up! It's the bearings in the heater fan. Try kicking it, sometimes it works..........!
FredTransit
Mk2 Trannyist
Postby jay » Wed Dec 14, 2005 3:28 pm
love the comment fred!!!
mk1 connect tourneo
jay
Postby FredTransit » Wed Dec 14, 2005 3:31 pm
jay wrote:Try kicking it, sometimes it works..........!
:lol: I frightened my Gary to death once whilst we were driving along in the big un, the heater started screaming so I kicked it, he didn't realise it was me. He thought the banging was coming from the gearbox!!! Shut up the fan bearings a treat though, till the next time!
FredTransit
Mk2 Trannyist
Postby Aragorn » Wed Dec 14, 2005 3:37 pm
cant see the kicking doing much on a mk5 as the blower is right up the back of the dashboard behind the radio... :p
i'll get a new resistor and switch and hopefully get it working soon :)
Aragorn
Postby FredTransit » Wed Dec 14, 2005 3:46 pm
Aragorn wrote:cant see the kicking doing much on a mk5 as the blower is right up the back of the dashboard behind the radio... :p
oh yeah, sorry I am always talking about the Mk2!!! Dunno about the kicking, but I still recken it's the heater fan bearings.
FredTransit
Mk2 Trannyist
Postby jay » Wed Dec 14, 2005 3:51 pm
dunno about kicking the heater..i kicked my van once...hell it hurt.. :D
mk1 connect tourneo
jay
