Removing a stripped torx bolt
Postby Ucof » Sat May 17, 2008 4:05 pm
I'm on the last of 6 T40 bolts that keep the driver's seat rails secured to the floor (Im trying to clean the cab properly), but unfortunatly, the chappie who last did it up (bless his little cotton socks) appears to have coated the thread of the bolt with superglue. So much so, that it won't rotate at all. In the slightest.
This has resulted in a fairly stripped T40 shaped hole, and the bolt still as tight as when I started.
I have tried a liberal amount of WD40, as well as different shaped drill bits (phillips, pozi, hex, flat) to see if any of them give any grip, but no luck.
Has anyone got any advice on how to remove the little b*stard? :evil:
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Re: Removing a stripped torx bolt
Postby Gavin » Sat May 17, 2008 4:15 pm
clean it, find a hex bolt that will go in the hole and weld it in, undo with socket and wrench. i had to do this with the torx bolts on my front anti roll bar
Gavin
Postby Luke » Sat May 17, 2008 4:17 pm
can you get to the ecxposed thread underneith - if you can grind it off (but not the nut bit) and you'll probly find the torx will undoo it :D as the heat from grinding will free it and theres no crap on the thread too :D
Postby Ucof » Sat May 17, 2008 4:20 pm
Gavin, Luke, thanks for the replies :)
Gavin - I don't have a welder - would pritt stick work? ;)
Luke - guess what! I don't have a grinder either! :( Could I just hold a butane lighter to it for a while then try it? There's no problem in getting to underneath it.
thanks again :)
Ucof
Powered by Nutella
Postby Luke » Sat May 17, 2008 4:24 pm
tbh i'd get an angle grinder - prolly cheaper than a refill of butane :lol:
but you could try - but you wouldnt have the extra help of no rusty threads going throung the nut :!:
Postby Ucof » Sat May 17, 2008 4:26 pm
TBH - I reckon that once it got started, it wouldn't be a problem. It just getting that first little bit of give in it and freeing it up so that I can unscrew the rest of it.
I'll see if the lighter trick works. :)
Ucof
Powered by Nutella
Postby bazw » Sat May 17, 2008 4:34 pm
try hammering a hex head bit into the torx head , this sometimes gets a grip when a proper torx does not
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Ucof » Sat May 17, 2008 5:04 pm
Lighter didn't not nearly almost in the slightest :( :(
bazw - thanks for the idea, I'll give it a go tomorrow - I've given up for today.
Ucof
Powered by Nutella
Postby Gavin » Sat May 17, 2008 5:16 pm
use a cold chisel and hammer a nick into the side of the head, then place a punch or drift on it at an angle and hit it with a hammer to drive it round
Gavin
Postby Ucof » Sat May 17, 2008 5:25 pm
Thanks Gavin, another good idea - only problem is that I haven't got that much access to it from the sides to turn it. If I did it from the top, I'd be forcing the bolt downwards rather than upwards. I'll have a play about with that idea and see what I can do. :)
Any more ideas? :?
Ucof
Powered by Nutella
Postby MrMPuk » Sat May 17, 2008 5:32 pm
That Torx bolt looks like if you use the right size it will be okay.
Postby Ucof » Sat May 17, 2008 5:38 pm
I have tried and tried and tried. :cry:
The Stanley T40 screwdriver (held with adjustable wrench) keeps slipping, as do the numerous T40 bits I have :(
It really is quite f*cked.
Ucof
Powered by Nutella
Postby MrMPuk » Sat May 17, 2008 5:40 pm
Maybe it's not T40 :idea:
Postby Ucof » Sat May 17, 2008 5:44 pm
The rest of them were, as was this one when I started ;)
Ucof
Powered by Nutella
Postby AlanN » Sat May 17, 2008 6:47 pm
Ive had to drill one out a while back, started with 1/8th and worked my way up, even managed to save the thread, but did put a nut on just incase
cron
