rumble from steering wheel?
Postby Lee J » Thu Dec 15, 2005 4:17 pm
Here's a new one for me, travelling down the road the other night and every now and again there is a rumble from the front end. I can feel it up the steering wheel. I have just had new front brakes fitted, I wonder if the wheels need balancing? Would this do this? Sometimes it's when I get up to 70mph it gets worse. It does feel like a balancing issue to me. Any other ideas?
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby pictishpunkgirl » Thu Dec 15, 2005 6:01 pm
You could check your wheel nuts have beeen put on tightly enough or that you don't have a defective tyre with a bulge in it. Are your steering components OK? I'm sure there will be other answers soon!
Morag
pictishpunkgirl
Postby rover » Thu Dec 15, 2005 6:27 pm
pictishpunkgirl wrote:You could check your wheel nuts have beeen put on tightly enough or that you don't have a defective tyre with a bulge in it. Are your steering components OK? I'm sure there will be other answers soon!
Morag
Sound like a good call to me, the tyre is the most likely, but there are always other options, have the brake callipers been tightened and the springs replaced correctly? is there plenty of fluid in the power steering resevoir?
What model is your van?
rover
Postby phil g » Thu Dec 15, 2005 6:33 pm
had same symptoms onc, all became clear when tyre exploded on motorway
"Transits"where would we be without em
phil g
Postby Gunslinger » Thu Dec 15, 2005 6:34 pm
when you say brakes do you mean pads or pads and discs ??
yes first check wheel nuts then caliper bolts then hub nut,
i know its hard to describe a "rumble" but does it feel like something knocking against the steering column or what ?
Gunslinger
Postby FredTransit » Thu Dec 15, 2005 7:38 pm
Is there a whining noise accompanying it? I am thinking wheel bearing. Jack up the front axle and see if there is any play in the front wheels, shake them side to side and up and down. Also look out for a grinding noise on braking due to a shift in the brake parts caused by a bad bearing.
FredTransit
Mk2 Trannyist
Postby jay » Fri Dec 16, 2005 9:41 am
if the disks have been done and the vibration wasnt there before....the bolts that hold the disks to the hubs may not be tightened properly!!!!!also could be the hub nut for the bearing may be over tightened ...take the van back to where you got the work done and tell them,they can check there own work and if its anything they done they will have to fix it FOC!if they wont trading standards come to mind!!
mk1 connect tourneo
jay
Postby Lee J » Fri Dec 16, 2005 9:46 am
OK fellas, thanks for the response. The front wheels where making a little squeak every now and then, I was told the brake pads we're down to the bone so I had them changed. This rumble does feel like something knocking on the steering column. It stops when I turn the steering wheel slightly one way or the other. It gets worse as I get faster.
Lee J
Postby Gunslinger » Fri Dec 16, 2005 10:19 am
it could be that the pistons in the calipers dont like being pushed all the way back in to accept new pads and one or more is sticking causing the pad to hit the disc unevenly, disc outrun springs to mind, this can be caused by either the hub to disc bolts not being tight, or similar torque settings, hub nut being a little loose probably not torqued in the proper manner or the disc is slightkly warped, answer is to have them check the outrun with a dial gauge if it is that then they need to re mount the hub to disc in a different configuration (ie turned one set of bolt holes round) then reasembled and rechecked.
Gunslinger
Postby Lee J » Mon Dec 19, 2005 10:00 am
ok people here's an update...
Took van back to garage to check bearings/balancing/brakes - all ok.
I have made a discovery though! When travelling at say 60mph and the rumble/knocking starts, if I put my foot against the steering bar, the bit that goes from the steering wheel through the floor - IT STOPS!
any clues?
Lee J
Postby rover » Mon Dec 19, 2005 10:33 am
Could be as simple as the UJ on the steering column or even the bottom bushes on the column.
Rover.
rover
Postby Gunslinger » Tue Dec 20, 2005 6:16 pm
so what your saying is that the rumble is either coming from part of the steering linkage, or is some form of vibration further down the steering system that is actually causing something closer to the steering wheel to rumble ... interesting, i guess all you ca do is check all the joints then bearings and see what you find
Gunslinger
