Just got my van back today and it feels like a whole new van. Bloody better after I just spent £750 on the machine.
It got a new flywheel, clutch, release bearing and 2 prop bearings all fitted and warrantied for a year. Still expensive but it means if it does foul up again I just throw it back ayt the garage that fitted it.
Apparently there was nothing left of the old flywheel, it's a dual mass one and it had separated. Mechanic said only fresh air was making it select gears.
There is a downside however.
At the end of the first motion shaft there is a bearing which sits inside the crank case. Well in mine this bearing had been destroyed and had shagged the end of the motion shaft. Garage recommended fitting a recon box but I think that if I buy the offending bearing from ford I can remove the gearbox and weld up the damaged part of the shaft and grind it down so as it fits.
As it is the garage put it all back together without the bearing in question and said it would work fine for a while but might kill the gearbox eventually.
Oh well back on the road for the moment!
Just wiondering if anyone else had similar problems with the mk6?
