Gunslinger wrote:i assume the side of your van that you are going to cut out is single skin .... sorry to suggest this after you already have your windows etc, but you might have wanted to consider what i did with my mk2 ... robbed the windows out of an LDV 400... as these have 2 piece frames fastened around the glass, and then those frames complete with installed glass are riveted into the van, much easier to mark up and cut !!
ok, back to your problem, did you take more windows than you needed from the minibus ?? .... if yes then get a rubber of the same size from your spares, and cut it in half.... this will give you a profile view of it, then use the glass as a template and draw around it, then measure the thickness of the rubber section that would be between metal and glass, this will give you a guide as to how much outside of the glass template line to cut,
as for cutting, be careful not to over heat the metal and cause it to warp, use the thinnest cutting discs you can get for your grinder (preferably 0.8 or 1.0mm stainless steel cutting discs) if your going to use an air saw, be careful it doesn't snag, an air nibbler might not be the obvious choice for cutting out a window, but might actually make a neat job of it, or if you have someone with a plasma cutter then that is an opinion, however test that as i am not sure how clean a finish this will produce
if your sacred, do this first on a spare piece of steel and then when you have it right use that as a template
Gunslinger wrote:LMAO ... don't mind Neil .... he gets a nervous twitch when some one mentions wind*ws
that reminds me ... must send that conservatory salesman around to your place
