Sticky Gear Problem
Sticky Gear Problem
Postby MrBlueSkye » Fri Jan 13, 2006 11:50 am
HI all, Can anyone put their finger on this one: Back in May I lost fifth gear in my R reg 100 lwb 2.5 diesel. I had the gearbox pulled and a new 5th gear cog put in to replace the original which had sheared from the drive spline. At that time they said that the clutch plate and thrust bearing were fine. Since having the repair done going from 1st to 2nd gear has always been a "few seconds longer than you want" especially when it's cold until I've been driving for a couple of minutes which I assume allows the gear box oil to warm up and thin. Today getting into 1st gear and then second gear has been a bugger and at times I have had to put the clutch pedal down again to engage those gears. Somethings wrong somewhere.
Has anyone got a suggestion as to what the problem might be.
MBS
MrBlueSkye
Postby madmark » Fri Jan 13, 2006 2:01 pm
unfortunatly the gearbox will most probly allways be like that from now on! :( the mt75 is good or bad , most have abit notchy on the gear change! they are a pian! a frend of mine spent nearly £400 getting his sorted out and its still the same! the best thing is to try and live with it or replace the box with a good one! :?
Postby stevew » Fri Jan 13, 2006 6:01 pm
Yep, mine is exactly like you describe. :(
When cold changing from 1st to second is a horrible gear crunching experience. It's enough to make you want an automatic :wink:
Adjusting the clutch made quite a difference for me.
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby madmark » Fri Jan 13, 2006 7:38 pm
:shock: trust me you dont want a auto! :lol:
Postby MrBlueSkye » Fri Jan 13, 2006 9:28 pm
stevew wrote:Yep, mine is exactly like you describe. :(
Steve
Ok any chance of telling me how to do it please
MBS
MrBlueSkye
Postby Nighthawk » Fri Jan 13, 2006 10:59 pm
If the clutch pedal is level with the brake pedal or there abouts, it's not a clutch adjustment issue. It's a good place to start though :)
Did a dealer do the transmission repair?
If the clutch adjustment is OK, I'd suspect a couple of possibles
1st and 2nd sycnro rings/hub are worn.
or
Incorrect assembly of the transmission which has increased the preload on the gear train. Sometimes slackening off the input shaft guide sleeve and removing the input shaft securing circlip and then resetting the countershaft bearings before rebuilding with the correct torque will help. As will setting the rear flange nut to the correct torque to ensure the mainshaft is all the way back in it's bearing.
or
If they aren't a dealer, did they use the correct oil, the MT75 doesn't like Extreme Pressure oil
Nighthawk
Postby 100ps_drw_hicube » Fri Jan 13, 2006 11:17 pm
Nighthawk wrote:If they aren't a dealer, did they use the correct oil, the MT75 doesn't like Extreme Pressure oil
have had previous experience of that,, the old hicube got a new box fitted by a backstreet garage got halfway home and it kinda seized up :shock:
turned out to be incorrect oil :x
100ps_drw_hicube
Transit Abuser!!
Postby bortaf » Fri Jan 13, 2006 11:40 pm
Mt's use a red oil very very similar to ATF.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby gemini » Fri Jan 13, 2006 11:41 pm
is there any synthetic oil for the mt75 gearboxes
gemini
Postby Nighthawk » Fri Jan 13, 2006 11:56 pm
bortaf wrote:Mt's use a red oil very very similar to ATF.
Not anymore m8 :lol:
It's brown now and smells nasty :(
The old oil was a red synthetic mix, the new one is 75w90 as used in almost all the other ford transmissions.
We used to have loads of fun with the red oils!
Type 9 5 speeds had a red oil with wasn't the same blend as ATF, and MT75 had a red oil which wasn't the same as either of the other 2.
Didn't take long for the box to explode with the wrong oil.
Nighthawk
Postby stevew » Sat Jan 14, 2006 3:48 am
Hmmm, OK.
Well this is confusing :lol:
So what gearbox oil should I have in my '97 LWB?
More importantly where do I get it?
Steve
stevew
Postby Nighthawk » Sat Jan 14, 2006 4:27 pm
The simple answer to that is
Go to your local ford parts dealer, they'll give you the correct oil as listed on ecat or on microcat.
:D
Nighthawk
Postby MrBlueSkye » Mon Jan 16, 2006 4:09 pm
Hi all the update to my original posting (which I note was Friday the 13th) is that something is definately not right with this gearbox. I'm now having big problems getting it into any gear at all, and then the next minute it will go into gear. Example I drove 1/2 mile to the shops this morning and coming back could only get 2nd and strugglingly into third. On parking it wouldn't go into reverse but after lots of buggering about / clutch in out / trying different gears finally went into reverse, and then went straight into 1st gear to level the van up. Any advances on the advice you have allready given will be greatly appreciated. The clutch pedal is level with the brake pedal.
MBS
MrBlueSkye
Postby MrMPuk » Mon Jan 16, 2006 5:21 pm
I'd take it back to who ever rebuilt the gear box!
Postby stevew » Mon Jan 16, 2006 8:08 pm
Hmmm,
My van is usually difficult to get into reverse. I have to change into other gears and roll a bit to get it in. Even then it sometimes pops out as I feed in the power. The first time it happened I cr***ed myself, it makes massive bang exactly like reversing into a BMW! :shock:
I have had success with other gearboxs flushing them out to remove any swarf but it's never a good sign when bits of metal come out :?
Nighthawk's your man I think!
Steve
stevew
