bottom hose catching on alternator help wanted
Postby Kevin Hawkins » Sun Jan 15, 2006 6:32 pm
i am trying to fit power steering to a pinto engine i have got all the pulleys p/s pump and the alternator fitted but alas the bottom hose is catching on the alternator fan blade. Does any one know if Fords made a longer hose perhaps fitted to the Granada or does anyone know if I could fit a short section out of the bottom of the radiator which would give me a bit more room? What would I need and where would I get the part from? (I have tried bending the hose out of the way but it is putting too much strain on it). Any help would be very much appreciated. I am sure there must be someone out there who has done this conversion.
kevin
Kevin Hawkins
Postby madmark » Sun Jan 15, 2006 6:36 pm
hi kev you could try ,maybe putting a piece of tube in it to extend it ,or if its all fords own set up they should do a correct hose for it! :)
Postby bortaf » Sun Jan 15, 2006 10:54 pm
What way do the pipes come out of the rad?
straigt or a 90Deg bend?, mine were straight but i fitted Mk5 cortina rad that had the 90 Deg bend, used Mk5 cortina pipes to match but idon't have P/S just a way of fitting different shapped hoses.
Sierra and granada are longer cos the sierra/granny rad is wider but i'm not to sure weither the shape is ok or not though.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
