Bosch Diesel Pump Injector Pipes
Postby Galahad » Sun Jan 22, 2006 6:30 pm
Right, E reg Transit 190 2.5 Diesel with a Bosch Diesel pump. Unfortunately, one of the cables on top of the engine rubbed a hole in the side of the front injector pipe!
Ford do not supply or make these anymore!!!!!!!
I managed to fabricate one from a later Lucas pump, bending it to fit, and it didn't even last a week before it sprang a leak, probably because it wasn't straight enough when bolted in and it caused tension.
If Ford don't do these pipes, does anyone know where I can get one from or is it a visit to a breakers?
Galahad
Postby 100ps_drw_hicube » Sun Jan 22, 2006 6:53 pm
i got a brand new set of injecter pipes for the banana engine with bosch pump i can send you a pic to see if they match if you want :)
100ps_drw_hicube
Transit Abuser!!
Postby bortaf » Sun Jan 22, 2006 8:55 pm
got a scrap non banana Di from an e reg you can have what you want off that being scrapped wed or thursday :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Thanks...
Postby Galahad » Mon Jan 23, 2006 12:26 am
for the offers chaps, but as a matter of urgency I need to get it tomorrow (Monday). I have a stack of cars to scrap and can't be without the Transit.
Anyone on here from around the Bath/Bristol area that can recommend a good breakers nearby?
Galahad
Re: Thanks...
Postby 100ps_drw_hicube » Mon Jan 23, 2006 9:27 am
Galahad wrote:for the offers chaps, but as a matter of urgency I need to get it tomorrow (Monday). I have a stack of cars to scrap and can't be without the Transit.
yes united vans there around bristol on the south side look in the suppliers section on this forum there details are there :wink:
100ps_drw_hicube
Transit Abuser!!
Bugger....
Postby Galahad » Mon Jan 23, 2006 1:58 pm
Ok, I tried United Vans (cheers), but it appears that my engine is older than the hills :(
Its got a 1988 Bosch Injection system on it, it has two bolts either side of each injector, cast iron, 'old as the hills' I'm told.
I cannot get the right injector pipe anywhere.
Slightly later model engines, the pipes are too short. On the older model the pipes stretch right back through the same gap under the inlet manifold as the other pipes.
Help! :cry:
Galahad
Postby 100ps_drw_hicube » Mon Jan 23, 2006 2:42 pm
hi have just called in my local yard and they dont have anything older than 88 and everything they have of that era isnt a bosch pump :( have you looked on ebay for people breaking vans etc
100ps_drw_hicube
Transit Abuser!!
Ebay...
Postby Galahad » Mon Jan 23, 2006 2:47 pm
Just looked, all too expensive when all I need is one pipe.
I am losing so much money today because of this one pipe its unreal :(
Galahad
Postby MrMPuk » Mon Jan 23, 2006 2:49 pm
Go to a diesel specialst and get them to make you one, wont cost you much either.
No joy...
Postby Galahad » Mon Jan 23, 2006 2:58 pm
already tried. 5 different companies don't do it, one company can, but they won't guarantee that the pipe will last very long (they said 5mins or 15miles).
Galahad
Postby MrMPuk » Mon Jan 23, 2006 3:00 pm
The only other thing I can say is get a union and reapir the old one then!
Unfortunately.....
Postby Galahad » Mon Jan 23, 2006 3:07 pm
Thats now disappeared!
Galahad
Re: Ebay...
Postby 100ps_drw_hicube » Mon Jan 23, 2006 3:13 pm
Galahad wrote:Just looked, all too expensive when all I need is one pipe.
you dont really have much choice do you :!: lose loads of money by not working or shell out a small fortune but at least your back on the road again
we couldnt get a set of pipes for one of our epic pumps scouted all the breakers still no luck ended up using a john guest plumbing fitting to join it all back van has done about 60k since then and still no leaks but this isnt a option to you as you said the old one dissapeared :(
100ps_drw_hicube
Transit Abuser!!
LDV/ Sherpa
Postby Galahad » Mon Jan 23, 2006 3:18 pm
Am I right in thinking that LDV's or pre-LDV's used Transit engines?
Galahad
Postby MrMPuk » Mon Jan 23, 2006 3:21 pm
Still to modern for what you want I think!
