Rear brakes locking up
Postby crazyscoot » Mon Jan 23, 2006 9:56 pm
Hi to all.....newbie to your superb site that i just cant drag myself away from!
Have a couple of questions, one of my rear brakes locks up with medium pressure applied. Ive changed the shoes and the cylinders fairly recently. It did it before this work and is still doing it now. Its a bit scary when the rear end trys to overtake the front in the wet! Its a 95 2.5 td swb 100.
Other question is about lowering it. What parts would i need to lower it all round?
And last question, i think my turbo has seen better days, it stil pulls great but i think the seals may have gone due to the amount of oil its started to use. Also the induction pipe (turbo to cooler/inlet manifold) is weeping oil and the inlet manifold is full of a really thick black sludge. Question is, is this normal or do i have shot turbo? :?
Thanks all and look forward to hearing from you.
Ian
crazyscoot
Postby Luke » Mon Jan 23, 2006 9:59 pm
i think you'd be better with 3 questions in 3 posts!! :D
rear brakes - probly the load sencing valve!
lowering - how low?? front would be pritty easy with custom made springs rear is more difficult!!
turbo - :? but dont sound too good to me :lol:
:D
Postby Sundowner » Mon Jan 23, 2006 10:34 pm
King Springs over here (australia) do some lowered front srings for your van
Leaf springs need to be pulled apart and reset, im getting this done soon
Sundowner
Re: Rear brakes locking up
Postby stevew » Tue Jan 24, 2006 3:22 am
crazyscoot wrote:And last question, i think my turbo has seen better days, it stil pulls great but i think the seals may have gone due to the amount of oil its started to use. Also the induction pipe (turbo to cooler/inlet manifold) is weeping oil and the inlet manifold is full of a really thick black sludge. Question is, is this normal or do i have shot turbo? :?
Ian
My turbo seems to leak oil quite a lot into the inlet manifold. With the price of new or even re-con units so high I'm reluctant to replace it. The engine doesn't use oil too quickly so I'm not too worried.
I've fitted a turbo gauge so that I can monitor the turbo pressure (also helps me increase fuel economy) hopelfully if it drops off I'll spot it and replace the turbo before burning all the engine oil.
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
Postby crazyscoot » Tue Jan 24, 2006 8:28 am
Sundowner wrote:King Springs over here (australia) do some lowered front srings for your van
When you say the springs need to be 'reset' does this mean removing leafs of the spring?
I remember years ago on MK1 & 2 escorts were lowerd, they used lowing blocks, is this not possible with the transit?
Negative reality inversion
crazyscoot
Postby FredTransit » Tue Jan 24, 2006 1:02 pm
I don't think it's possible to use blocks, bear in mind this had been built to be a load carrier, and has been enginered to do that. Have you got coil springs? I have leaf springs like sundowner so don't know about other stuff.
FredTransit
Mk2 Trannyist
Postby Luke » Tue Jan 24, 2006 1:27 pm
crazyscoot wrote:I remember years ago on MK1 & 2 escorts were lowerd, they used lowing blocks, is this not possible with the transit?
this isnt possable cos on the tranny the axle is under the leaf spring on the mk2 escort it is on top :(
so loweing blocks will raise the van :?
Postby 100ps_drw_hicube » Tue Jan 24, 2006 2:46 pm
i wouldnt worry to much about the turbo they are strong units and if looked after you will easily get 200k out of it both our td hicubes leak oil into the manifold and neither seem to use any oil it just needs the inlet manifold cleaning out every 50k or so :)
100ps_drw_hicube
Transit Abuser!!
Postby crazyscoot » Tue Jan 24, 2006 6:52 pm
100ps_drw_hicube wrote:i wouldnt worry to much about the turbo they are strong units and if looked after you will easily get 200k out of it both our td hicubes leak oil into the manifold and neither seem to use any oil it just needs the inlet manifold cleaning out every 50k or so :)
is it possible to take the inlet manifold off without removing the injection pump. It looks to me like the pump has to come off in order to get to one of the manifold bolts. And the rear manifold bolt looks a bugger aswell!
As far as the blocks are concearned........think i'll leave them and maybe just get bigger wheels :lol:
crazyscoot
