Trouble getting ignition casing off.
Postby fingers » Sat Jan 28, 2006 12:56 pm
:D Hi Guys,
I have just bought an ignition from transit bill(thanks bill),and now i dont know how to get the other ignition off,the key was stuck in the barrell and i tried to get it out with no luck,even tried getting the barrell out by pressing the litte pin on top of barrell,no luck,so now i have sawn the front of the barrell off and smashed off the steering lock, took off light,wiper and indicator arms,removed steering wheel but the ignition casing will not come off am i doing something wrong or missing something out.please help guys,thanks.Fingers. :lol:
fingers
Postby Nighthawk » Sat Jan 28, 2006 9:23 pm
The aluminium steering lock housing was held onto the steel shaft surround by a pinch bolt, but as a security measure the bolt was designed to shear off when tightened.
If you look at the top of the housing you'll see a raised section with a kind of slope on it. to remove the housing you'll need to either drill the remaining bit of the bolt out or cut it off.
Did you turn the key in the barrel before pressing the release pin?
Nighthawk
Postby TRANSITBILL » Sat Jan 28, 2006 9:44 pm
:D hi Fingers ,disconect the battery for safety,undo 10mm bolt or t40 star bolt on column in engine bay,undo 4 13mm bolts holding colomn to bulkhead in engine bay ,recover plate...........undo 2 13mm bolts holding colomn under dash easy to get to ,remove column by pulling out van from in cab........... :D look at top of casting i sent you you will see a 13mm threaded stud with a slit sawn in it...............you need to do this sawing to yours and remove screw turn .........then you need to turn your castings guts to no1 to release steering lock pin, .simply saw head off your old barrel pull guts out with pliers,turn barrel to no 1 and slide old casting of column ,slide on replacement and tighten down the threaded screw.should you have nackered up your exsisting colomn pm me as i do have one in the old shed somewhere .........refit column and bobs your uncle........... (why disconect battery.just incase steering knuckle arm flops on to starter motor ) :D :D :D
TRANSITBILL
Postby TRANSITBILL » Sat Jan 28, 2006 11:53 pm
:P ps excuse spelling mistakes was eating me dinner at same time lol (best excuse i could come up with lol ) :oops:
TRANSITBILL
Postby fingers » Thu Feb 02, 2006 9:38 pm
:lol: Thanks Nighthawk,Thanks Bill,
I did what you both said and the barrell is now fitted,although sawing the pinch bolt out was a bit of a headache, but its done now, cheers guys.Keith (fingers) :lol:
fingers
