f*****g cam belts
f*****g cam belts
Postby bazw » Fri Feb 03, 2006 5:14 pm
hi al oh what fun ive had today
cam belt went ping when i started to crank the engine its bent 2 pushrods
the big question is will the valves be ok as they are still sitting flat in the head and are the same height as the others to within a few thou so i dont think they have bent at all
will get 2 rods from the scrappy in the morning but wonder if i should pull a head and snaffel 2 valves as well
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby 24vMk2 » Fri Feb 03, 2006 5:32 pm
Yup, they should be ok, have done many a transit cam belt.
Time her up, fit new pushrods, set the tappits, turn key! :D
24vMk2
Postby pictishpunkgirl » Fri Feb 03, 2006 5:57 pm
Your other reply is probably right but i'd snaffle all the pushrods & valves JUST in case! It'd be a pain if you had to go back.
pictishpunkgirl
Postby Nighthawk » Fri Feb 03, 2006 7:04 pm
Valves will be fine, check all the rods for distortion on a flat surface though as some will bend very very slightly.
Also make sure there are no tight rockers when you remove the rocker shaft and be sure to examine the rockers and pedestals for cracks.
Nighthawk
Postby bazw » Fri Feb 03, 2006 7:39 pm
been through the rods on a glass plate just 2 bent , thankfully i have not got this engine to start yet so it was only on the starter my mate was watching the engine and said it looked to kick backwards a bit as it went so i think im getting close to a start up anyway :)
at least i will know the timing is ok when im finnished
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby bazw » Wed Feb 08, 2006 5:49 pm
its alive alive i tell you
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Transit-Tricky » Wed Feb 08, 2006 5:53 pm
hurrah! Yipee! Back on the road again! :lol: :lol: :lol:
Zippy drives a Transit! Image
Transit-Tricky
Postby bortaf » Wed Feb 08, 2006 7:00 pm
well done :D
you obviously didn't break it properly :lol:
I managed to crack 2 pistons snap 2 rocker posts and bend 4 rods, and it was only idling when the belt went :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby FredTransit » Thu Feb 09, 2006 10:43 am
bortaf wrote:well done :D
I actually wonder if that's the worst time it can go! Ours went on the A2 going to Dover once, only did 3 pushrods. Got off light.
FredTransit
Mk2 Trannyist
Postby bortaf » Thu Feb 09, 2006 2:16 pm
You've seen me Fred, light and Bortaf don't go together :lol:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
