Box Or Clutch ? or maybe both !
Postby Andy » Sat Feb 04, 2006 11:38 pm
1988 Chassis cab - started life as petrol now diesel of unknown age! I wil post a picture of the engine at some point for someone to identify.
Anyway van is undergoing rust remedy treatment at the moment so the engine and gearbox are out.
When I bought the van and drove it home the gearbox was happy to go up the gears but required speed matching to go down the gearbox (if you know what I mean). Its an MT75 with evidence of leaking oil around the central seal. The engine is covered in oil all over the rear face and behind the flywheel. It looks like it is coming from the rocker cover gasket which is clearly Knackered. That said I have not removed the clutch to get a better look.
Anyway do you reckon the gear selection problem is the clutch or gearbox?
I got a new clutch on ebay -£21.00 - hope its the right one - 267mm.
But should I change the box aswell. They are not quite as plentifull up here in Scotland !!
Andy
Postby Luke » Sat Feb 04, 2006 11:43 pm
to age the Di - the year is cast into the head under the top hose!!! :D
Postby jay » Sat Feb 04, 2006 11:48 pm
for diesal engine types look here http://fordtransit.org/forum/viewtopic.php?t=2550
check your old clutch to see if it has oil contamintion that may have caused a problem with the gearchange...if it still do it when put in the van then its new gearbox time :(
mk1 connect tourneo
jay
Postby baconsdozen » Sun Feb 05, 2006 12:25 pm
Could be clutch drag or,maybe more likely (espicially if the box went in gear from a standstill OK) its the synchro on the way out (unusual for them all to go though) I'd be inclined to see what happens with the new clutch.
baconsdozen
Postby madmark » Sun Feb 05, 2006 1:31 pm
the mt75 is a strange box ,you can have a exelent one thats smooth and give no problems or you get a notchy one! sometimes a clutch will help abit! ,not shure about the clutch size mate you will have to take it off and have alook. 242mm springs to mind! :)
Postby bortaf » Sun Feb 05, 2006 4:19 pm
Mine was a pig to change down and get into first when standing still, new cable and ratchet soon sorted that (of course it blew up 2 weeks later but i can't blame the clutch cable for that can i) :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby rover » Sun Feb 05, 2006 6:48 pm
I would think that your change down from 5 to 4 is ok? but 4-3 and 3-2 is a pain? if so then thats almost certainly the synchros, if its a pain in all gears then probably a new clutch will sort it.
Mine was sometimes a pain to get into 1st but other than that it was smooth as silk, its not a pain at the mo cos its sat on axles stands with no propshaft :shock:
Rover.
rover
Postby Andy » Tue Feb 07, 2006 10:13 pm
I'll top it up with oil and give it a go with the new clutch - maybe a new cable aswell.
Will keep you posted.
Thanks for the info.
Andy
Postby Andy » Thu Feb 09, 2006 8:36 pm
Wrong f***ing clutch !
Anyone want one with a (267mm) - dont know what it should fit,but it does fit on the mt gearbox.
Andy
Postby gemini » Wed Feb 15, 2006 1:23 am
Andy wrote:Wrong f***ing clutch !
TRANSIT 2.5 DIESEL INJ TURBO MT 75 G /BOX 1989 - 91 267 MM
gemini
Postby Andy » Wed Feb 15, 2006 10:01 pm
Thanks for the info -
After all that the clutch cable is Knackered - still I'm glad I changed the clutch as thats one less thing to go wrong !!
P.S Engine back in and running sweet with no smoke - Lovely !
Andy
