Where is all this oil coming from !
Postby Andy » Thu Feb 09, 2006 8:40 pm
My non banana 89 2.5di is covered in oil making it difficult to find the source - where is the most common source of leaks?
Lots of oil especially on the exhaust side - I'll be doin the rocker cover and sump gasket as a matter of course but if you can advise of any other known bad spots
cheers
Andy
Postby FredTransit » Thu Feb 09, 2006 8:42 pm
Could it be coming out of the oil PC valve? or did you ever forget to put the filler cap back on and drive for a bit (ya might have remembered that one)
FredTransit
Mk2 Trannyist
Postby rover » Thu Feb 09, 2006 8:57 pm
If its all over the place then the rocker cover is usually the biggest culprit, just make sure the engine is not breathing heavy or the breather blocked before you change the gasket, otherwise you will blow the gasket straight out again.
Rover.
rover
Postby bazw » Thu Feb 09, 2006 9:00 pm
the most common leak on any motor is the rocker cover
if like the di its pressed steel ,they get over tightened and this kills the sealing gasket . when i rebuilt mine last week end i looked at the rocker cover and it was distorted around each bolt hole where it had been over tightend
couple of mins with a hammer and dolly and the mateing surfaces were true or just a little hollow so they compress square
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Andy » Thu Feb 09, 2006 9:15 pm
Where is the oil PC valve?
I'm not too familiar with this - or any diesel - engine !
Andy
Postby FredTransit » Thu Feb 09, 2006 9:25 pm
Andy wrote:Where is the oil PC valve?
Doh! The oil PC valve I was thinking of is on the passenger side on the PINTO! I have just nipped outside to refresh my memoury, and ya know what I couldn't find it!!! Anybody tell ME where it is?? Anybody? :oops:
FredTransit
Mk2 Trannyist
Postby rover » Thu Feb 09, 2006 9:29 pm
You tell me what it is Fred and I'll tell ya where it is..
Rover.
rover
Postby FredTransit » Thu Feb 09, 2006 9:32 pm
rover wrote:You tell me what it is Fred and I'll tell ya where it is..
Rover.
It's the Pressure Control Valve, on the pinto it's just above the passenger side engine mount in the block, has a big pipe going into it, if it pops out it allows the oil to splatter out of the block (not p*ss) all over that side of the engine bay.
Oh, and while I was under the bonnet of me diesel (early, lucas pump) I noticed there was quite a bit of oil about too, coming from the rocker cover joint, quite normal I thought!
FredTransit
Mk2 Trannyist
Postby rover » Thu Feb 09, 2006 9:56 pm
Oh, I would have called it the 'crankcase pressure valve', different areas different descriptions I suppose..
Anyhow I wasnt aware that the Di had one, I think its just the breather on the top of the oil filler cap..
Cant find one on the TIS disk anyhow..
Off to the pub now, its quiz time :D
Rover.
rover
Postby bazw » Thu Feb 09, 2006 10:18 pm
no pcv on a nana been all over mine as i played with it over the weekend on a bench
all venting for the crank done through the oil ways and cam chamber to the rocker than out of that big oil filler/vent into the manifold and burnt
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby gazza » Fri Feb 10, 2006 2:39 am
PCV, positive crankcase ventilation as memory serves from capri days, whos closest mr nighthawk? is there a prize? :lol:
gazza
Postby FredTransit » Fri Feb 10, 2006 10:08 am
if there isn't one on the Di, that'll be why I can't find one! Now you mention it, there is a breather on the oil filler.
FredTransit
Mk2 Trannyist
Postby madmark » Fri Feb 10, 2006 1:15 pm
:shock: di ,s dont have them fred! its old petrol engine that have them like the essex! :)
the di is famous for leaking from the O ring inside the fuel lift pump, but on a 89 i dont think you will have one, but it may of had another engine at some point so check there!
i am haveing the same problem at the moement with mine! :?
Postby pictishpunkgirl » Fri Feb 10, 2006 1:38 pm
As with the other replies i'd see how you get on once you've done the rocker cover gasket - ours was pishing oil & we found the bolts really loose on the rocker cover and it's been OK since we tightened them - still a bit leaky but we'll change the gasket soon anyway.
pictishpunkgirl
Postby stevew » Fri Feb 10, 2006 1:42 pm
madmark wrote:the di is famous for leaking from the O ring inside the fuel lift pump
Is that the replacable O ring between the pump and the block or actually inside the sealed pump? It's a bit late since I've replaced the whole pump now :P Oh well it stopped leaking anyway!
Steve
Van Cam, service suspended (no van!) (no cam either!)
stevew
