madmark wrote:yes fred get the tank as empty as you can fill with diesel and away you go, now if it was one of your pinto,s then you would have a big bill on your hands!
maddogf3 wrote:Its the Cat that gets damaged it overheats because of higher combustion temperatures
That cause the cat to overheat and melt resulting in a blocked exhaust .Garages like to take the tank out and clean all the fuel lines and a new filter , why because they can then ligitimately charge £300
Cats dont like going over 900deg
Users browsing this forum: metalworker0
