starter problem
starter problem
Postby ryzman » Sat Mar 04, 2006 9:15 pm
1996 transit tdi turn the key to start, starter turns over but will not stop even when ignition is off any ideas bump starts fine and don't here anything from the starter
[color=#4040BF]umm nice mk6.. 85ps swb l/r executive... hybrid turbo.. modded injectors... decat... 225/70/r15 tyres... remap by van tuner... loads of torque... lovely jubley
ryzman
Postby Luke » Sat Mar 04, 2006 9:16 pm
sounds like the starter solenoid sticking in!! :D
Postby MrMPuk » Sat Mar 04, 2006 9:18 pm
Are you saying the starter doesn't stop turning over or the van wont turn off?
Postby ryzman » Sat Mar 04, 2006 9:37 pm
the starter won't stop turning
ryzman
Postby MrMPuk » Sat Mar 04, 2006 9:37 pm
As Luke says then!
Postby ryzman » Sat Mar 04, 2006 9:41 pm
cool i thought it was starter but just being lazy really instead of investigating problem thought i'd ask cos thought maybe back of ignition had turned
ryzman
Postby Luke » Sat Mar 04, 2006 9:47 pm
ryzman wrote:cool i thought it was starter but just being lazy really instead of investigating problem thought i'd ask cos thought maybe back of ignition had turned
i think you can strip off the soleniod and clean it out! you could be 100% sure its that by un plugging the small lead off it while its doing it!
if it stops then its the ignition if it carries on then its deff. the starter sol.
:D
Postby ryzman » Sat Mar 04, 2006 10:05 pm
yeah i did that pulled the small exciter wire off and starter carried on well i got six starters so not a problem cheers
ryzman
