Has anyone got any good results from Injector cleaner?.I'm wondering if the ones you add to a tank of diesel work or not.I've also noticed the additives that are supposed to improve cold startng and give a bit more go anyone got any thoughts?
wynns diesel clean-up, proffesional formula injector cleaner, most motor factors sell it, it is designed to be poured straight in the filter, and it works, another good one is forte
Forte is brilliant, if I have a Diesel in for M.O.T that fails on emmisions the first thing I do is pour a bottle in the tank, take it for a run around the block and 9 times out of 10 it will then pass the emmissions test.
It aint cheap at around a tenner, but its worth it.
