stevew wrote:Most AT power supplies were relatively low power by todays standards at 250-300W. They usually only supplied 5-6A on the 12V rail
but I guess if you're into rewinding the transformer then you could have all 300W. I.e. 21A at 13.8VA nice power supply.
...I used to use an old AT PSU as a 12V supply all the time and it was great, almost indestructable!![]()
Steve
Rolo wrote:Without having to do anything like soldering some loading resistors across the voltage outputs you weren't using?
For the use I want it for (to occasionally help the solar panels charge three battery banks through the solar regulator) it would be great if I could simply put the 12 volt and 5 volt outputs in series for a total output of 17 volts, and without even having to open to PC power supply.
stevew wrote:You can't series up the 12V and 5V supplies because they have a common ground connection. You could go between the -5V and 12V outputs but the -5V supply is usually very small, like 500mA so it wouldn't be much use.
The supply you finish up with won't have any current limiting so at 17V it would be easy to cook it if your batteries are big.
Sundowner wrote:Is this some kind of home made auto battery charger
how much would it cost in time and parts???
Rolo wrote:Steve:
How about using two PC power supplies with the 12 volt 10 amp and 5 volt 20 amp outputs in series with each other for a total output of 17 volts 10 amps?
Rolo wrote:And if I use three PC power supplies (a have plenty of old ones) I could connect two of them with their 12 volt 10 amp outputs in paralell and then a third one using its 5 volt 20 amp output in series with the other two for a total output of 17 volts 20 amps, and without even having to open any of them, but what about their 230 volt primaries?
Rolo wrote:The supply you finish up with won't have any current limiting so at 17V it would be easy to cook it if your batteries are big.
A 50 watt 1 ohm resistor (or less - made from electric heating wire) or a headlamp in series could take care of that current limiting but surely if I connect that 17 volt output directly in parallel with the solar panels the solar panel regulator should take care of that while at the same time giving the batteries exactly the boost and float voltages they need.
My solar panels produce between 17 and 21 volts, they already have isolating diodes (so they don't drain on each other when one of them is in the shade) and another 40 amp 65 volt Schottky diode on the output of this PC power supply setup should take care of the rest to prevent any voltage feedback from the solar panels into the ps regulating circuits, I think,.. or I used to think therefore I used to be.
stevew wrote:You could do that but you'd have to be absolutely sure that the outputs of the power supplies were isolated from the inputs and probably the case.
A resistor would do it I suppose although it seems like a waste of power.
You could use your regulator but only if it's the right type.
Rolo wrote:You could use your regulator but only if it's the right type.
I know for certain that it isn't a shunt type because when there is no charge the voltage on the regulator input goes up.
Normally you need shunt type regulators with wind type voltage regulators so that the electrical load of the shunt acts as a brake and prevents the blades from overspinning when the batteries don't need the high current and you are not using any power.
stevew wrote:Exactly. The problem is that a lot of solar regulators are just on off type. They connect the panels to your battery untill the battery volts come up and then disconnect them. That's fine for solar panels but might draw too much from the power supply without a dropping resistor in series.
Just fit a fuse to be safe.
Steve
UK_ANDY wrote:Old Fords never die - they just go faster
