SWITCHING FROM PETROL TO LPG ?? TRANSIT MK6
Postby manxtransit » Thu Jun 04, 2009 7:55 am
Just a quick question, I have just bought a 2002 transit with the factory lpg system fitted.
Starts and runs fine, if I drive for about 5 mins and then press the lpg switch after a
couple of secs van will cut out (as though it has run out of fuel) It will then pick up again after about 5-6 secs and the green lpg light (under the lpg fuel guage) will flash about every 3 secs.
Is it then running on lpg or has it tried to switch to lpg and then gone back to petrol, hence the cut out and then picking up again?
Thanks for any help :D
manxtransit
Re: SWITCHING FROM PETROL TO LPG ?? TRANSIT MK6
Postby whitevanman66 » Thu Jun 04, 2009 10:31 am
if i switch mine whilst driving it makes no difference at all in the way it drives,smooth switch over? i dont know...im not sure if i should switch ignition of then back on before it actually switches over if you get what i mean...my green light never flashes though,its either on or its off...mines a very late smiley mk5(late 2000) but its a factory fitted system
whitevanman66
Postby madmark » Thu Jun 04, 2009 1:18 pm
manxtransit wrote:Just a quick question, I have just bought a 2002 transit with the factory lpg system fitted.
it should not do this ,if its a factory conversion it will automaticly go over to gas unless you switch it over! you have a problem its not going onto gas by the sounds of it! :roll:
Postby manxtransit » Thu Jun 04, 2009 2:00 pm
it should not do this ,if its a factory conversion it will automaticly go over to gas unless you switch it over! you have a problem its not going onto gas by the sounds of it! :roll:[/quote]
Whats the correct procedure then?
Should I just start it with the lpg switch on and then the van will switch from petrol to lpg when it can?
Or should you start it on petrol and then when warmed up press the lpg switch and it will switch onto lpg?
What should the green light under the lpg guage be doing? Staying on or flashing?
]One other thought I have just had is the lpg guage shows full , as high as it can go, maybe the sender or the guage is faulty and there is no lpg in tank?? Is there a way to check the sender and guage?
Sorry for all the questions :D
manxtransit
Postby madmark » Thu Jun 04, 2009 5:20 pm
the van will start on petrol and when its ready it will automatic go over to lpg, unless its not a factory conversion, the way to tell if its factory is the dash ,you should have a rev counter and the petrol gauge does lpg and petrol! :wink: also the filler will be on the oposite side to the petrol filler cap! :wink: also the door stickers will have the duel fuel logo on them! :wink:
Postby AndyG » Thu Jun 04, 2009 5:30 pm
madmark wrote: the way to tell if its factory is the dash ,you should have a rev counter and the petrol gauge does lpg and petrol! :wink:
Don't the LPG MK6s have a gas gauge in place of the temperature gauge :?:
Postby madmark » Thu Jun 04, 2009 5:49 pm
andy from memory i think the petrol gauge does both! :wink:
Postby manxtransit » Thu Jun 04, 2009 6:48 pm
yes there is 2 fuel guages, 1 on the far right for petrol and 1 on far left for lpg, this is the 1 that is reading maximum, need to find out if it is reading correct or is faulty
manxtransit
Postby rovert » Thu Jun 04, 2009 8:25 pm
Maybe water in the LPG evaporator This is located at the lowest point in the LPG system and any water in the system will collect here,reducing the efficiency of the evaporator
rovert
Postby coconut » Thu Jun 04, 2009 8:29 pm
madmark wrote:it should not do this ,if its a factory conversion it will automaticly go over to gas unless you switch it over! you have a problem its not going onto gas by the sounds of it! :roll:
Not strickley true on the mk6's, yes you can start with the lpg switched on and it will start and run on petrol until warmed up but you can also switch the lpg off and run solely on petrol and switch on and off of lpg as required :wink:
Has the lpg system ever been serviced, both filters, pressures set at both stages etc :?:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby Rowdey » Fri Jun 05, 2009 4:45 pm
manxtransit wrote:it should not do this ,if its a factory conversion it will automaticly go over to gas unless you switch it over! you have a problem its not going onto gas by the sounds of it! :roll:
I always start/leave the LPG on (light on the switch) and it will move over to LPG when it good and ready, about 45 secs i suppose.
As far as i can tell, the flashing green light (which is under the LPG tank gauge, which has replaced the TEMP gauge) is a sign that the LPG is on call and awaiting (auto) switch over once temp is reached.
You ( i can anyway..) hear a relay or similar, click over (some times twice) and green then stays permanently on.
If you worry about LPG guage being faulty, why don't you just fill it right up to check :? It will go back to petrol automatically when LPG runs out. I get a miserable 150 miles from a tank (but have a leak to sort) so thats a starting point of expected milage from a tank full.
A word of caution - my petrol tank has shown over 1/4 full, and still run out of petrol.. :x
03 Dual Fuel MR MWB and now 66 Mk8 L2H2..
Rowdey
Postby madmark » Fri Jun 05, 2009 5:30 pm
mate what you have said is what i ment!
:wink:
Postby manxtransit » Fri Jun 05, 2009 9:42 pm
Now sorted guys :D
Went and filled the lpg, took 48ltrs
So the guage or sender unit is faulty as it certainly wasnt full! It now switches over fine and the green light under the guage stays on permanently , doesnt flash.
Thanks for all the suggestions :D
Also, how easy is it to service the lpg side , ie change any filters, and where can they be purchased from?
manxtransit
Postby mealic » Mon Sep 06, 2010 10:19 am
Bump!!
We have tried to sort my problems(well LPG ones anyway) at Billing this weekend to no avail. :( Mine does exactly this..............does not switch from petrol to gas.
We have changed the small filter(thanks guys)but where is the other one located.
MK6 `04 2.3 petrol/LPG
`04 2.3 petrol/LPG
mealic
Postby Rowdey » Mon Sep 06, 2010 9:58 pm
mealic wrote:Bump!!
Search button does wonders.. :)
http://fordtransit.org/forum/viewtopic.php?f=2&t=45851&p=409735&hilit=lpg+filter#p409735
Thanks to Coconut
Rowdey
