mk1 overdrive unit and gearbox
Postby yellowperil » Wed Mar 22, 2006 10:13 pm
Does anyone know what wiring up a mk1 overdrive unit involves and does the mk1 gearbox mounting have to be moved as well as shortening the prop somewhat? :?:
yellowperil
Postby FredTransit » Wed Mar 22, 2006 10:21 pm
Sixwheelphil should know, he's fitted plenty of OD boxes, though not sure if he's domne one in a Mk1.
FredTransit
Mk2 Trannyist
Postby yellowperil » Wed Mar 22, 2006 10:27 pm
Thanks for that Fred Im still on the quest for more relaxed revs for my pinto when it goes in next month.
yellowperil
Postby FredTransit » Wed Mar 22, 2006 10:35 pm
Even if he hasn't done one on a Mk1, I am sure the priciple is the same (like I would know)
FredTransit
Mk2 Trannyist
Postby yellowperil » Wed Mar 22, 2006 10:40 pm
I think the mk2 has a removeable crossmember and the mk1 has an underslung welded mount?
yellowperil
Postby FredTransit » Wed Mar 22, 2006 10:42 pm
Good point, I had forgot about that. Maybe you can weld on the mounting bracket, to a Mk2 box.
FredTransit
Mk2 Trannyist
Postby yellowperil » Wed Mar 22, 2006 10:59 pm
Yes you probably could ,I ve got the chance of obtaining a mk1 unit and as the gearbox mount is going to be moved when I go pinto ijust wondered whether fomoco used a crossflow gbox mounting for the v4 with od. This makes it a bit more complicated fitting the od box to my pinto fitted exv4 flat fronted van as I was using the extra room for cooling stuff.Donor mk1 is ex crossflow
yellowperil
Postby FredTransit » Wed Mar 22, 2006 11:01 pm
I am also thinking Baconsdozen did this too, but could be wrong.
FredTransit
Mk2 Trannyist
Postby Luke » Wed Mar 22, 2006 11:14 pm
FredTransit wrote:I am also thinking Baconsdozen did this too, but could be wrong.
this may be of some help!! :D
http://fordtransit.org/forum/viewtopic.php?t=776
Postby madmark » Thu Mar 23, 2006 5:15 am
:? if you have the old style gearbox mount then its no good, you will have to get the overdrive crossmember that fits the overdrive box! and the overdrive propshaft!! :wink:
Postby yellowperil » Thu Mar 23, 2006 10:33 am
Cheers for that Mark I know the score with that now,i ll contact the seller to see if he has the whole kit.
yellowperil
