priming a new fuel filter mk6 deisel ford specal tool
Postby scottscotland » Sun Jun 07, 2009 11:41 am
priming a new fuel filter ,i just looked in the manual for mymk6 it says i need a ford specal tool (hand priming pump) :?: :?: :?: it makes diy servicing hard when you need a ford specal tool ,is there another way :?: :?:
i was going to fill it with deisel and stick it on :D :D
scottscotland
Re: priming a new fuel filter mk6 deisel ford specal tool
Postby fedup2 » Sun Jun 07, 2009 11:44 am
When changing the fuel filter have some diesel to fill up the filter.warm the engine to hot. have a vehicle and jump leads avaiilable.
Fill the filter and wind till it goes.mk6's can be twits.
Launch x431 owner ;)
fedup2
Postby easymove recovery » Sun Jun 07, 2009 7:55 pm
my filter got filled with diesel 1 day and we still ended up dragging it around 5 mile to get it going
i have now found if u fill it with forte diesel treatment instead of derv it runs and dont stop wierd i know but it works
EASY MOVE RECOVERY
VEHICLE TRANSPORTATION & 24 HR RECOVERY
NOTTINGHAMSHIRE BASED
easymove recovery
Postby LRN » Sun Jun 07, 2009 9:45 pm
I do 2 or 3 a week.
Just fill them with Diesel and fit, start engine and get the revs up immeadiately for 15/20 seconds.
Can't say i've ever had any trouble, all run fine from the off.
LRN
Postby tinkadill » Sun Jun 07, 2009 9:48 pm
i have only ever done 1 on the van in my sig, and nevr thought of it being an issue just filled it with forte diesel treatment and had no problems :wink:
Transit 330 swb Van semi high top 2.4 diesel 53 plate
tinkadill
Postby jamsyboy » Tue Jun 09, 2009 10:04 pm
same here guys just changed filter filled with derv turn key keep revs up and bobs er uncle all done.. :D
transit mk6 t350 lwb,twin batteries,superchipped...she's my little work horse
jamsyboy
Postby tourneo2002 » Mon Jun 15, 2009 10:53 am
Just to add to the guys that fill the filter, it is not a quick job, fill it, let the level go down then gradually keep topping up the filter until it will not take anymore, allow around 5 minutes for this. Then simply fit the filter, start up and away. If it is not quite full, then it may start, but because of low fuel pressure you may get white smoke out the exhaust for a few minutes. DO NOT DRIVE IT UNTIL YOU HAVE FULL PRESSURE !!!
tourneo2002
Postby vansit1 » Sun Mar 30, 2025 12:11 pm
do i also need to fill in the main fuel line that comes in from the front right or does the hp pump create its own suction via the filled up filter then?
someone also suggested to plug up the rear left line on the filter side with a wiener, but what line is that and what would this help to fix?
vansit1
Postby dumper » Sun Mar 30, 2025 1:49 pm
tourneo2002 wrote:Just to add to the guys that fill the filter, it is not a quick job, fill it, let the level go down then gradually keep topping up the filter until it will not take anymore, allow around 5 minutes for this. Then simply fit the filter, start up and away. If it is not quite full, then it may start, but because of low fuel pressure you may get white smoke out the exhaust for a few minutes. DO NOT DRIVE IT UNTIL YOU HAVE FULL PRESSURE !!!
That’s all I do if you tap the side of the filler you can see air bubbles come to the top it makes it a bit quicker
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby vansit1 » Sun Mar 30, 2025 3:23 pm
what about the right front fuel line itself?
vansit1
Postby dumper » Sun Mar 30, 2025 4:25 pm
vansit1 wrote:what about the right front fuel line itself?
Never ever removed the pipe just fill the filter as described and start it with some ribs on
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby knobby1 » Sun Mar 30, 2025 9:32 pm
vansit1 wrote:do i also need to fill in the main fuel line that comes in from the front right or does the hp pump create its own suction via the filled up filter then?
Thread is 16 years old...the person you're replying to is long gone and hasn't been on here since 2013.
Start a new thread with your issue.
