diff gearing
diff gearing
Postby yellowperil » Fri Mar 24, 2006 11:06 pm
OK then has anyone fitted a later transit crownwheel and pinion (mk2 or 3) into a mk1 type 27 diff housing?(single wheel)Or fitted a mk1 diff input flange to a later diff? :idea: :?:
yellowperil
Postby Luke » Sat Mar 25, 2006 10:16 am
not yet but i'd guess it will fit!! mk3 to mk1/2
the complete mk3 axle will fit on a mk1 but its 25mm wider
the only difference is the propshaft flange - but that might be interchangable!!
:D
Postby yellowperil » Sat Mar 25, 2006 10:25 am
Im goin to try it i ll have a spare mk1 diff off soon and i ve got all the pulling gear to get the flange of cold.Anyone got a decent mk3 diesel type27 back axle pref 4.11
yellowperil
Re: diff gearing
Postby Rolo » Sun Mar 26, 2006 9:38 am
yellowperil wrote:OK then has anyone fitted ... a mk1 diff input flange to a later diff? :idea: :?:
I fail to see why it should even be an issue as long as you use the flange from the "spare" axle and you join them at the driveshaft bearing.
Just my theory since I have no experience with that type of job so wait around to see what anybody else has to say on this subject.
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby yellowperil » Sun Mar 26, 2006 1:21 pm
Yes I see your point Rolo as long as the u/j is the same.But I cant see it being much of a job to change the input flange as long as the input shaft diameter mic s up the same.
yellowperil
