madmark wrote::shock: i am still on drumsi need to convert to discs!
Rolo wrote:No, not vented and I'm reasonably certain that it doesn't have 4 callipers either.
Rolo wrote:So it will be a straight swap with the Mark 2 6 stud front axle but what do I have to do to fit those brakes in the dual wheel rear axle without changing to a 9" diff?[/b]
Sundowner wrote:just separate your hub and disc and the vented discs will bolt right on
but be prepared for a shock when you want to overhaul your brakes
It works out cheaper to fit the falcon discs and get an engineers
Sundowner wrote:Im sorry mate the falcon conversion wont work with 6 stud
If you have a 6 bolt front end the vented discs and 4 pot calipers bolt right on
The front vented discs and 4 pots bolt on with no mods on a 6 stud van
The rear brakes are a bolt on but i have a nine inch diff in my van
Vented with 6 stud hub on the left and non vented 5 stud on right
