Which size tyre is the best bang for the money?
Postby Rolo » Fri Mar 31, 2006 3:41 am
When I recently mentioned to a friend that I was considering changing from 14" to 15" wheels when and if I get a rear axle out of a Mark 4 he mentioned to me that there is a lot less to choose from in LT tyres in that size and they are much more expensive and a quick google search seems to confirm that opinion, which then begs the question; if that's so then why did Ford change the wheels to 15" in the Transits"?
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
Postby MrMPuk » Fri Mar 31, 2006 6:28 am
Gotta say i'm running 15s now and had a much bigger choice of tyres as nearly all new vans are running on at least 15s.
Postby Sundowner » Fri Mar 31, 2006 7:00 am
14" tyres are a pain to get
the 15" tyres on my EL are $60ea
Sundowner
Postby Rolo » Fri Mar 31, 2006 7:43 am
Are we still talking LT (Light Truck) 8 ply tyres?
And what's an EL?
Rolo
Postby Smooth Hound » Fri Mar 31, 2006 2:31 pm
I am sorry to break the news to you, Ford arent interested in saving you money on tyres, They have probably got shares in the tyre industry, No seriously a 15 inch tyre is a fraction dearer, but it goes round slightly slower and lasts slightly longer. :)
Smooth Hound
Postby wheelerstyres » Fri Mar 31, 2006 3:23 pm
hi tyre prices and info
i can get both easy enough 195/14or 195 /15
hankook are best value for money they are not a remould and are a nice ride price wise i charge £56 fitted for 14 in and £58 for 15 in
the newer transits which have215/75/16 are a different story
hope this helps
wheelerstyres
Postby rover » Fri Mar 31, 2006 3:40 pm
Thats not gona help Rolo much though eh? :lol: :lol:
Rover.
rover
Postby Rolo » Sat Apr 01, 2006 2:10 am
rover wrote:Thats not gona help Rolo much though eh? :lol: :lol:
Rover.
Why not?
It might conflict with the information I was given up to now and also with what I could find by myself in the net but who said all posters have to agree with anybody's preconceived ideas on any subject?
Did I mention yet that I believe Transits are rubbish and we should all be driving Sprinters instead? :roll: :D
Rolo
Postby Rolo » Sat Apr 01, 2006 2:19 am
wheelerstyres wrote:hi tyre prices and info
So you wouldn't say that one size is more popular and more easily available (and therefore cheaper) than the other? (and I wasn't referring just to that $2 difference)
And while I have your attention, since you deal with tyres, could you please explain to me how is it that there is only 3 mm difference between the overall diameter of a 195R14 (666mm) and a 205/75R14 (663 mm)?
Doesn't the "/75" part indicates it is a lower profile tyre?
Rolo
Postby MrMPuk » Sat Apr 01, 2006 2:47 am
You haven't put the full details for the 14 inch tyre but the 75 bit for the 15 inch tyre refers to the side wall profile, 75 means 75 % the width of the tyre.
So a 205 tyre with 75 profile would have a side wall of about 174mm. This is something I have kinda covered in a few posts, if you play around with your tyre sizes you can fit bigger wheels and still keep the speedo the same as before by fitting different tyre profiles.
Postby Rolo » Sat Apr 01, 2006 5:04 am
MrMPuk wrote:You haven't put the full details for the 14 inch tyre
I thought I did.
The tyres are 205/75R14, which you confirmed is a 75% low profile tyre, so how could it be only 3mm (1/8") smaller in overall diameter than a 195R14, which I presume by the lack of a "/XX" is a 100% or standard profile tyre?
[quote]So a 205 tyre with 75 profile would have a side wall of about 174mm.[/quote}
Which should make that 205/75R14 about 62mm smaller in overall diameter, not just 3mm, correct?
(205-174=31 mm X 2 = 62 mm)
Rolo
Postby MrMPuk » Sat Apr 01, 2006 6:07 am
To have a 14 inch 195 tyre it would have to have a wall profile of 85 to be the same diameter as a 205/75r15. I haven't got a clue what you are talking about in your last post but have a play here and you can see what size tyres and stuff you can get to give you the same rolling ratio.
Postby Rolo » Sat Apr 01, 2006 6:48 am
MrMPuk wrote:To have a 14 inch 195 tyre it would have to have a wall profile of 85 to be the same diameter as a 205/75r15. I haven't got a clue what you are talking about in your last post
Maybe because you keep bringing up that 205/75R15 while I'm talking about a 205/75R14 tyre. :)
I'll check it out, thanks.
Rolo
Postby Rolo » Sat Apr 01, 2006 7:07 am
I think the light is coming on now after checking that site.
Is the tallest tyre profile 80 and should I assume that when a tyre is shown as a 195R14 without any "/50" or "/75" after the "195" that tyre has an 80% profile by default?
Rolo
Postby MrMPuk » Sat Apr 01, 2006 7:14 am
Ok then 195/80r14 is the roughly same diameter as 205/75r14. 195/80 has a wall of 156mm and 205/75 has a wall of 153.75mm making a difference of 4.5mm, which works out to be a 0.7% difference in circumferance.
