how to mark up fuel pump before removing
Postby cyclone » Mon Apr 03, 2006 10:53 pm
hi, guys seals gone on my fuel pump have managed to get it repaired for
£70 + vat ,but i need to take the pump off i need to no how to mark up the pump so as i dont muck up the timing!can anyone tell me step by step
what i need to do the van is a 1992 transit swb100 2.5d non turbo with a lucas cav pump thanks in advance for any advise
regards
cyclone
Postby bazw » Mon Apr 03, 2006 11:29 pm
you need to set it to the pin stops and leave the pins in the cam and flywheel , remove the plastic front cover and then the cam belt
the pump can then be removed
if you are asking this then i am guessing you have little experiance on the di ,if so a haynes manual will be a must first buy to get you through this
they are only £15 ish and well worth it
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby gemini » Mon Apr 03, 2006 11:35 pm
scribe a mark on both the pump and casing before you remove it so you can bolt it back up in the exact position it came off
gemini
re
Postby cyclone » Tue Apr 04, 2006 6:55 pm
good sound advise guys this is my first transit so iam a little bit slow ,but i will learn.thanks guys
regards
cyclone
Postby Nighthawk » Tue Apr 04, 2006 7:38 pm
The pump will go back in the correct position because the 3 mounting bolts into the timing plate don't allow it to move. Some even had a small dowel in the timing plate to ensure a perfect alignment.
Once you have the pin in the flywheel, camshaft and pump the timing belt fitment is pretty easy. and there's enough information on here to help you nail it.
If you do get stuck, there are some great peeps on here who'll be more than willing to assist.
Nighthawk
