noiseman wrote:Thought about making some of my own rather than paying for a full kit to do a range of engines I will never own.
Any help appreciated.
Imperial isn't dead, the last to jobs I had everything was imperial. Mainly due to the equipment being from America, every now and a again I get to work with whitworth.
you need the hole that goes straight through, the other holes dontbondy wrote:if you use a pin which is too small in dia in the flywheel, you can get it in the wrong hole. the bitch will never start.the 2 holes are about an inch or so apart.
