oil everywhere
oil everywhere
Postby monkey » Mon Apr 17, 2006 11:08 am
recently bought a 1992 lwb high top i intend to turn into a camper. havin run it for a month as a commuter, including motorway mileage.
i yesterday did 300 miles on the motorway at about 70 and seem to have used 3 litres of oil, having never used any in the last month. the bottom of the engine is covered n i cant work out where its coming from, the oil pump is the front most point that is covered in oil but the surrounding area isn't. are there any particular places i should look as i dont know transits well yet?
monkey
Postby FredTransit » Mon Apr 17, 2006 11:16 am
Welcome monkey, try looking above the oil to the dryer bits of the engine. It's going to be a seal or gasket of some kind, maybe the rocker cover or believe it or not did the filler cap come off? All transit engines have some kind of oil leak or other, but not usually to the extent of using 3L. Is there any smoke? Blue-grey smoke is a sign that the engine is using the oil, engine using iol is down to either the valve guide seals or piston rings worn. Is it petrol or diesel by the way?
FredTransit
Mk2 Trannyist
Postby Luke » Mon Apr 17, 2006 11:32 am
3 litres :shock: check the oil filter is tight :!:
Postby monkey » Mon Apr 17, 2006 1:13 pm
its a diesel. is there any gaskets i should look at in particular. any that are under particular pressure? the oil pump's got oil on it, but not the engine mount behind it which i thought would be covered if it was that leaking. just cant figure it out :x
monkey
Postby monkey » Mon Apr 17, 2006 1:15 pm
its not burning oil cos a friend followed me the entire journey. the subframe beam is also covered. where abouts do the oil pump in and out go to ?
monkey
Postby Luke » Mon Apr 17, 2006 1:29 pm
if the pump has oil on it i'd go for the rocker cover gasket - easy one anyway!!! :D
Postby crazyscoot » Mon Apr 17, 2006 1:54 pm
monkey wrote:its not burning oil cos a friend followed me the entire journey. the subframe beam is also covered. where abouts do the oil pump in and out go to ?
Bet your mates pleased with all that oil over his windscreen :? Could you use some gunk and a jet wash to clean it all off then have another look after a short jouney
Negative reality inversion
crazyscoot
Postby monkey » Mon Apr 17, 2006 1:54 pm
where is the oil pump? i think i was looking at the power sreering pump :? the leak's lookin quite far back on the engine.
monkey
Postby Smooth Hound » Mon Apr 17, 2006 2:12 pm
I would also give the oil filler cap/breather a good soak in petrol or some type of cleaner as if it is a bit choked with carbon then the build up of pressure that would occur on a 300 mile motorway journey would not be sucked into the air intake manifold (the banana) enough and pressure would build up and force it passed the rocker cover gasket.
Also dont over tighten but check the rocker cover bolts are not loose.
Good luck. Mike
Smooth Hound
Postby monkey » Mon Apr 17, 2006 3:41 pm
cheers for the rapid replies guys, legends! will do that. just looks like the oils closer to the back of the engine but ill look
monkey
Postby pictishpunkgirl » Mon Apr 17, 2006 4:45 pm
Ours looked as if it was pouring out the back but tightening the rocker cover gasket, as smooth hound said, helped.
pictishpunkgirl
Postby madmark » Mon Apr 17, 2006 5:02 pm
the most prone spots are
1 the rocker covergasket
2 oil filter houseing
3 fuel lift pump on the side of the block if you have! :wink:
