Wendy, I'm no expert, but with my woman logic I would do following:
1. Make sure all the wires are correctly connected onto the battery
2. Check the main connection socket is connected properly (ehm... not sure what is it called - the big one you see on the main wire coming from the battery)
3. Check all the fuses are in working order and plugged in
4. If no fault found until this point, I would charge up the battery with a charger and try running it again OR take the battery to be tested by professional (might be that the battery is old/lacks liquid OR is just not able to be recharged)
5. If none of the above works, it might be the alternator not functioning properly, but wouldn't this show on the dashboard warning light??? Someone?
I would think it is the battery, simply because they could have drained the battery to minimum whils installing the cameras and being too old, battery just doesn't charge up anymore. Again - I'm no expert, but I would think this might be the case. Try charging it with a charger to full and see what happens. Not sure how much the garage charges to check if the battery is working...
Hope you resolve it soon, let us know!
