ford radio 2000 traffic Problem!
Postby matthew » Tue Apr 18, 2006 5:20 pm
When i put the radio on it flashes up 1 hour and then comes on. But then when im going down the road and after an hour it goes off, how do i extend the time the radio is on for.
MatT
matthew
Postby MrMPuk » Tue Apr 18, 2006 5:27 pm
The 1 hour thing is for when the ignition is off, if it does it with the ignition on then I would say it has lost the ignition feed. It could be that it has been wired up wrong, but I would check the fuses first.
Postby matthew » Tue Apr 18, 2006 6:03 pm
will check them, cheers
matthew
Postby matthew » Wed Apr 19, 2006 10:18 pm
there was a fuse blown so have replaced it and still it has not sorted it out, whats the next thing to check.
matthew
Postby MrMPuk » Wed Apr 19, 2006 10:36 pm
Pull the stereo out and see what feeds you have behind it, I think there might even be a fuse in the back of the stereo.
