100ps_drw_hicube wrote:crow bar![]()
have you checked all the wires running to the rear doormight have a broken wire/ bad connection
Nighthawk wrote:IGN key from OFF to POSII (run) 8 times within 10 seconds ending with the battery light ON (posII)
The vehicle will signal learn mode by cycling the door locks in sequence
press a button on the fob
the vehicle will then confirm the learnt code by cycling the door locks for a second time
program another fob now in the same way if needed
Turn off the ignition to exit learn mode and the door locks will cycle to confirm.
daddy cool wrote:Think normally if one of the wires is broken, the doors won't lock at all.
Nighthawk wrote:A few suspects
poor wiring condition between the O/S/R door and the corner pillar
poor door adjustment on the rear
latch failure within the O/S/R door
That fact that the interior lights are coming on when the blue button is pressed tells you that the remote fob and it's battery are OK, and that the CSM is seeing the signal to unlock.
Try unlocking the vehicle using the drivers side door lock barrel and key
turn the key to the lock position twice whithin 3 seconds, the vehicle should dead lock and flash the indicators.
now unlock the vehicle twice in the same manner as you locked it, if it still doesn't open the back door it's deffo fubar.
