vibration on steering wheel
Postby paj » Fri Apr 21, 2006 4:09 pm
i am getting vibration on the steering wheel when i brake,suspecting warped discs,is there anyway of checking without the need for a special tool.van i s a 2000 smiley
paj
Postby AndyG » Fri Apr 21, 2006 5:40 pm
What's your mileage :?:
TECHNICAL PROBLEMS& QUESTIONS
Postby BigMac » Fri Apr 21, 2006 5:55 pm
I HAD THE SAME PROBLEM I PUT NEW DISCS ON ONLY TO FIND IT WAS THE BACK BREAKS THAY HAD SOME OIL ON THE SHOES SO DO LOOK AT THE BACK BREAKS BE FOR YOU BUY NEW DISCS
BigMac
Postby paj » Fri Apr 21, 2006 5:57 pm
54000 miles
paj
Postby gemini » Fri Apr 21, 2006 6:05 pm
most likely cause is a balancing weight has come off the wheel
gemini
Postby AndyG » Fri Apr 21, 2006 7:26 pm
Mine started at about the same mileage and as you say only happens when you put your brakes on and probably from about 50mph it's worse I would say DISCS :(
:idea: Do the pads at the same time though :wink:
Postby MrMPuk » Fri Apr 21, 2006 7:39 pm
The way to check for warped discs is to ride the brake pedal a little and if the pedal moves up and down then it's warped discs
Postby Luke » Fri Apr 21, 2006 7:56 pm
try swapping the back wheels to the front - if it goes its the wheels if it stays it aint :? :D
Postby Nighthawk » Fri Apr 21, 2006 9:37 pm
I can't believe no one has mentioned using the handbrake yet :shock:
Drive to a speed where you know the judder happens
making sure traffic around you isn't going to be endangered, pull up on the handbrake lever keeping your thumb on the lever release button to prevent the ratchet from engaging.
If there is NO judder, it's most likely warped discs
If it still judders with only the handbrake applied it's most likely distorted wheels rims and drums.
Either way, i hope your cheque book can stand it !
A judder through the steering wheel without braking would be wheel balance, you usually drive in and out of the range of vibration on that too.
Transit.........Job done
Nighthawk
Postby 100ps_drw_hicube » Fri Apr 21, 2006 9:45 pm
Nighthawk wrote:Either way, i hope your cheque book can stand it !
:lol: :lol: :lol: discs arent too expensive! :D neither are new wheel rims :D £50ish each if i remember rightly :?
100ps_drw_hicube
Transit Abuser!!
Postby Nighthawk » Fri Apr 21, 2006 9:55 pm
you must have deep pockets m8
100 quid for discs, another 40 or so for pads and then new wheel bearings as well because 9 times out of 10 they'll be noisey or you'll damage them getting them off.
and then the 1.8 hours labour charge for just doing pads and discs.
best part of 2 to 3 hundred quid there.
Drums are around 120 each and then the wheels...........christ i need to sit down, i'm getting a cold sweat thinking about someone having to spend this much money :D
Nighthawk
Postby 100ps_drw_hicube » Fri Apr 21, 2006 10:04 pm
ye i meant pattern parts or from transit parts :wink:
got me some new drums from transit parts last year(gen ford)£54 each :shock: :shock: discs and pads£52 :shock: and the labour is free if you do it yourself :lol: :lol: :lol: but agree with that labour charge my dad had frauds fit new discs and pads and new shoes and handbrake cables last year all parts supplied by us they charged him £322 and had the van for 2 days because they couldnt get the bolts out of the discs :shock: :evil:
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Sat Apr 22, 2006 3:56 am
:shock: :shock: i am starting to go off the mk6! :? :?
Postby baconsdozen » Sat Apr 22, 2006 8:33 am
Hello Hicube I agree the labour charges is high (always have been when you compare them to peoples wages per hour) but I've some sympathy with the garage and the bolts holding the discs on.
I did the same job on my Merc a week or so ago and despite the fact that I sell tools and so have more than even a well equipped workshop I had a terrible time undoing bolts that had been undisturbed for twenty odd years.The heads seemed easy to distort and I eventually had two break off flush.Incidentally over the years I've still found nothing to beat the original Plus-Gas as a releasing fluid,always interested in other peoples opinions on alternatives.
baconsdozen
dics
Postby paj » Sat Apr 22, 2006 11:38 am
will try everything mentioned, i have replaced discs about three times on my past vans and i must have been lucky cause never had problems getting old ones off, always thought it was a easy job dont think it has many black spanners in the manual either!. a friend of mine has just had the back shoes done on his mark 6 and it cost him near on £200 trouble getting drums off,cant believe the difference in price for the parts on the mk6 .
paj
