mis reading speed clock
Postby Jim H » Sun Apr 23, 2006 5:35 pm
Help,got a Mk5 chassis cab with a 4.63:1 diff. The problem is at an indicated 30mph it's realy doing 37mph so the speedo drive pinion is the wrong one. does anyone have a list of pinion teeth or colour to axle ratio so i can fit the right one and not get done for speeding please?
Cheers
Jim
Plodding along.
Jim H
Postby madmark » Sun Apr 23, 2006 6:06 pm
jim you need to pay a visit to your dealer and get them to look to see what drive you need ! :wink:
Postby Jim H » Mon Apr 24, 2006 9:01 am
good idea, will do ,Thanks
Jim
Plodding along.
Jim H
dealer
Postby Jim H » Tue Apr 25, 2006 6:29 pm
OK, been to our local dealer only to find there are 3 optsions for my diff ratio. Can't quite understand that. Anyone got any ideas?
4.63:1diff MT75 box. 21or22or25teeth speedo drive?
Plodding along.
Jim H
Postby transitgeoff » Tue Apr 25, 2006 10:21 pm
get your vin number, details from the diff tag,details from the gearbox sticker and phone Ford technical £1 a minute so make sure you have all the info, or maybe ask mr Nighthawk as dealers access Ford technical free :wink:
transitgeoff
Postby Jim H » Fri May 05, 2006 7:58 am
It turns out that for a 4:63to1 salisbury axle you need a 21 tooth speedo drive. Found this out by having a guess, then going back to the dealer, speaking to a very helpful parts dept man. I can only believe the first bloke i spoke to was a Muppet!
Plodding along.
Jim H
Postby Pilch » Fri May 05, 2006 2:18 pm
I am having troubles with mine too (only from a three hour drive last night). Not sure if it it is too fast / too slow but it also picks and chooses when it wants to work. I have a tachograph fitted in mine which I'm not sure is standard or not / affects how a normal speedo would work. I will be taking a look at it tomorrow and will pass any info i gain on. Cheers
Pilch
Postby Jim H » Sat May 13, 2006 5:27 pm
73 Down hill 45 up, hmmm me thinks me needs a turbo. Mind you it is a big heavy truck.
Plodding along.
Jim H
