LUCAS EPIC PUMP MANUAL ?
Postby AndyG » Thu Apr 27, 2006 6:08 pm
This pump has had nothing but bad press on this forum and even though mine's been great up to now, it's probably only a matter of time before it gives trouble.
I thought it would be nice to know exactly what makes this pump tick :?
What adjustments are available :?:
What actually goes wrong :?:
Why it costs an absolute fortune to put right :?:
Why has mine always been noisy and reliable :?:
Does anybody know if a manual is available :?:(book or CD not pump)
So what if I'm opening up a can of worms :?:(let 'em out :!: )
Postby crazyscoot » Thu Apr 27, 2006 6:32 pm
when mine went tits up, i scoured the net for the electronic parts, in a bid to get it working again without replacing the whole thing, did i find any info? did i heck! That was about 3 years ago, it may be different now though.?
Negative reality inversion
crazyscoot
Postby AndyG » Thu Apr 27, 2006 6:38 pm
So yours went wrong electronically :?: not mechanically :?:
What were your symptoms :?:
Postby crazyscoot » Thu Apr 27, 2006 6:49 pm
Used to go into limp home mode when you hit 60mph. Used to have to pull over, kill the engine, wait about 3 mins start her up and off you go again. Had a scary moment on the motorway in a contraflow, the limp home cut in and i couldn't get out of the outside lane because of inside lane traffic! Glad ive done the conversion :D
To be honest, i couldn't say to you, yes it was electronic. But my gut feeling was that it was and so i searched for the electronics because i thought it must be the cheapest way of getting it back on the road.
crazyscoot
Postby AndyG » Thu Apr 27, 2006 7:08 pm
Probably just a dry joint :roll: :!: :?:
Nothing a bit of high temperature solder couldn't sort out :lol: :lol:
Postby AndyG » Thu Apr 27, 2006 8:52 pm
crazyscoot wrote:Used to go into limp home mode when you hit 60mph. Used to have to pull over, kill the engine, wait about 3 mins start her up and off you go again. Had a scary moment on the motorway in a contraflow, the limp home cut in and i couldn't get out of the outside lane because of inside lane traffic! Glad ive done the conversion :D
Did you not suspect a sensor :?:
What's the maximum speed in limp home mode?
Can you use all the gears still :?:
Postby 100ps_drw_hicube » Thu Apr 27, 2006 8:56 pm
i managed 55mph in los mode 5th gear too :? its usually a actuator inside the pump that goes wrong :( im sure if you could get the bit you might be able to do it yourself :? :? :?
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu Apr 27, 2006 9:02 pm
This is exactly what I was thinking :idea: We could fix them ourselves :D Why not :?:
Save a fortune on converting to manual pumps. And besides manual pumps no good on my van :(
Tune them up a bit and every body will putting these back into their vans :lol: :lol:
Postby 100ps_drw_hicube » Thu Apr 27, 2006 9:09 pm
that and your epic is different to that for a manual engine :evil: :evil: so your kind of restricted in all ways :evil: i wonder if lucas would sell the required parts???
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu Apr 27, 2006 9:13 pm
100ps_drw_hicube wrote:that and your epic is different to that for a manual engine :evil: :evil: so your kind of restricted in all ways :evil: i wonder if lucas would sell the required parts???
He better do :!: Or I'll change his name :lol: :lol: Nah, If they don't I'll find someone that they will :D
Postby 100ps_drw_hicube » Thu Apr 27, 2006 9:19 pm
other than lucas i cant think of anywhere that would sell the parts :? :?
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu Apr 27, 2006 9:21 pm
100ps_drw_hicube wrote:other than lucas i cant think of anywhere that would sell the parts :? :?
Delphi Group :?:
Haven't you still got an old pump :?:
Postby tim » Thu Apr 27, 2006 9:23 pm
I have never seen a manual for the epic pump,i even tried my mate who worked in the lucas factory in Gillingham in kent.There is no adjustment everything has to be done on a computer which is for the epic pump thats why not every diesel shop can do them,it seems the equipment needed costs a lot of dosh so a lot of dosh prices.Anything can go in them,i got my one done[£600] it went in to limp mode and 3 weeks later something else went and when i took it back to the diesel man,tough sh*t mate its an epic another £400 quid please.my mate in lucas recons the lifespan is between 1mile to 250.000 miles .After 4 pumps none with the same problem i changed to the bosch manual pump[more power,no hassle,more mgh
A WORK OF ART IS A JOY FOREVER
tim
Postby 100ps_drw_hicube » Thu Apr 27, 2006 9:24 pm
yes :D been to a derv pump specialist in portslade who wants £550 to put it right :? they say it's a specialist job that only experienced technicians can carry out :roll: and they wont touch it if the paint seal has been broken :evil: which mine has :roll:
100ps_drw_hicube
Transit Abuser!!
