with the following result
P0606- Transmission control module processor error
P0717- ISS Open circuit
P0810- Clutch position control error
P0812- Driver interface reverse push button
P0909- Gate Secret position control error
P0919- Gear shift position control error
P02711- Unexpected mechanical gear disengagement
B1319- Drivers door switch malfunction
U1900- Can communication bus fault
Requires further diagnosis for ASM transmission fault or wiring harness fault.
The reason I wanted to get the error codes read was because I had a flashing transmission warning light flickering on my dash for the last few months now. I did go to a couple of auto electricians but they reported no faults at all. This time it was done by the local Ford dealer and obviously only their equipment can read this thing properly.
The van drives fine but I do remember once having a problem with the gears not shifting back down. That was a couple of months ago now and it hasn't happened since.
Can some of you guys explain some of these faults to me or is there a table I can look them up on?
I do have a TIS copy but I'm pretty sure they're not mentioned on there.
PS I also wonder if some of these errors had to do with the break in my rear door harness which caused my central locking to fail. (that's fixed now but I wonder if there's another problem related to that since when I use my rear wipers on intermittent, the interior light in the cabin comes on for a second when the wipers do their sweep)
