injector pipes
injector pipes
Postby gateshead » Thu Apr 27, 2006 11:28 pm
Im converting my 100ps td to bosch manual pump :D and was wondering do ineed new injector pipes or will old lucas system do? :?:
By the way this is a great forum 8)
gateshead
Postby gateshead » Thu Apr 27, 2006 11:34 pm
sorry forgot to say van is actually twin wheeler ldv ex police ,yes I know im already a member of ldv sherpa but they dont seem to be as clued up there as you guys are here with the exception of tim from ireland hes spot on and post on both forums!
gateshead
Postby 100ps_drw_hicube » Thu Apr 27, 2006 11:38 pm
i think you will find the old lucass ones will be ok!!!
100ps_drw_hicube
Transit Abuser!!
Postby gateshead » Sat Apr 29, 2006 3:06 pm
are you 100% sure mate?
gateshead
Postby crazyscoot » Sat Apr 29, 2006 3:45 pm
yep! they fit :D
Negative reality inversion
crazyscoot
Postby tim » Sat Apr 29, 2006 3:46 pm
The bosch ones would be best as they are in pairs and they will fit down cushty between the gaps in the manifold seperatly.The lucas ones will do at a push but as the four are together it makes life a little harder to get them to the pump,in the past i have had to do a little shaping
A WORK OF ART IS A JOY FOREVER
tim
