calnetaxis wrote:I have been to two different mechanics and they have both come up with the following solution
The problem is with the injection pump.. I have seen this many times - and your symptoms fit - and added to that , the death knell is the P0251... indicating internal pump failure ( or at this point - trouble )
Your best bet is to have this looked at further by a Diesel Specialist wherever you live, if you havn't done so already - but the pump needs to come off and either be replaced - or, I would suggest, if you can do without the van for a while, its cheaper to send it off for repair..
HAVE YOU TRIED CHANGING THE INJECTION PUMP ON YOUR TRANSIT AND IF SO WHAT WAS THE OUTCOME ?
calnetaxis wrote:Well weve got ours sorted - we took it to a Ford Dealer and they did an injector test - found two injectors were leaking - replaced two injectors then did the test again only to find that a third injector was leaking. Replaced the third injector and everything running ok - job done !!!
spanner-86 wrote:hi people i know iv been away a whileis it fair to say that the majority of fuel concerns is due to poor fuel quality and/or poor servicing
spanner-86 wrote:hi people i know iv been away a whileis it fair to say that the majority of fuel concerns is due to poor fuel quality and/or poor servicing?
