smiley axles
smiley axles
Postby mk 1 kincaid » Tue Nov 24, 2009 7:17 pm
my transit smiley its a swb semi hi top. my question is can i take the six stud heavy duty axles of a 190 van and put them onto mine is it just a strait swap over thanks all :D
mk 1 kincaid
Re: smiley axles
Postby Luke » Tue Nov 24, 2009 7:19 pm
whats your van :?: :D
Re: smiley axles
Postby mk 1 kincaid » Tue Nov 24, 2009 7:53 pm
its just td swb normal axles i fancy the heavy axles thanks
mk 1 kincaid
Re: smiley axles
Postby Luke » Tue Nov 24, 2009 9:07 pm
yes then they should fit :D
but not 100% sure if the prop mounting flange is the same :D
for the fronts the 6stud brakes are bigger - same calipers but different pads carriers and disks - might aswell do that mod too :D
Re: smiley axles
Postby mk 1 kincaid » Tue Nov 24, 2009 9:22 pm
so front whish bones brakes springs hubs etc the rear axle and try to find a 150 prop shaft and that should be me is this right thanks :D
mk 1 kincaid
Re: smiley axles
Postby Luke » Tue Nov 24, 2009 9:27 pm
front all you need are the hubs and the brake bits i mentioned :D wishbones are the same :D the part of the hub with the stub axle on is the same too :D
somone esle might conferm if you need the prop i'm not 100% sure on it :?
Re: smiley axles
Postby MinorMatt » Tue Nov 24, 2009 11:41 pm
I have a LWB 5 stud axle on my LWB 6 stud van... so I assume they are interchangeable! :lol:
Re: smiley axles
Postby mk 1 kincaid » Wed Nov 25, 2009 6:07 pm
thanks lads you have been a good help thanks :D
mk 1 kincaid
Remk2 axles
Postby billy-boy » Thu Feb 25, 2010 8:36 pm
hi boys thinking about fitting single 16inch wheels to my mk2 twin wheeler can you use front stub and wheel bearing from mk2 with the disc and hubbs from mk3 cheers billy
billy-boy
