rev counter/speedo
rev counter/speedo
Postby steviebee » Thu May 04, 2006 4:40 pm
Hi All Im new to this forum so be gentle with me! I have just read about fitting speedo and rev counter from mondeo TD into the transit. I was wondering if the speedo has to be recalibrated or does it work ok. My van is a 1999 2.5 Di I believe it was made in malaysia? It has the earlier style dashboard the one with two radio holes. it has full service history and is in very good condition apart from a little bit of rust on rear wheel arch and drivers door. Any info on speedo or malaysia imports appreciated as this is my first Transit and it is all new to me.
steviebee
Postby MrMPuk » Thu May 04, 2006 4:50 pm
Have a read of this and then decide if you really want to bother!
http://fordtransit.org/forum/viewtopic. ... 49&start=0
rev counter
Postby steviebee » Mon May 08, 2006 8:49 pm
Hi, sorry I didn't reply sooner but have had to work all over the weekend and had no time to check out the forum. It does seem to be a lot of work just for one extra instrument, but I have always been a glutton for punishment when it comes to fitting bits and pieces to cars & vans. I will give it a go this weekend (if breakers still has mondeo diesel in)
Regards
Steve.
steviebee
Postby AndyG » Mon May 08, 2006 9:18 pm
Firstly before you start, you need to establish if you have a mechanical cable driven speedo or an electronic one :wink:
rev counter
Postby steviebee » Tue May 09, 2006 2:21 pm
Hi Andyg, Have the mechanical one, just got revcounter from scrappies. Will fit at the weekend and let all know how I get on
Regards
Steve.
steviebee
rev counter
Postby steviebee » Sun May 14, 2006 5:16 pm
As promised report on rev counter. I fitted it last night took 50 mins from start to finnish no problems at all, just had to run the white/black wire from third terminal on alternator. Must admit looks good when lit up at night. Feel free to ask any questions if you are going to fit same.
steve.
steviebee
Postby 100ps_drw_hicube » Sun May 14, 2006 5:18 pm
how about doing a how too???? :D
100ps_drw_hicube
Transit Abuser!!
rev counter
Postby steviebee » Sun May 14, 2006 5:24 pm
Ok will right it up and post it
Steve.
steviebee
Postby 100ps_drw_hicube » Sun May 14, 2006 5:28 pm
thanks :D still aint got round to finishing my old mans one :roll: :lol: :lol: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby Ecosse » Sun May 14, 2006 6:30 pm
Can this dash change be done if you (or "me" in this case :D ) have the electronic speedo version?
Does the later mondeo have an electronic type dash, and if so does it fit?
Cheers
Alex
Ecosse
rev counter fitting
Postby steviebee » Sun May 14, 2006 6:48 pm
Please note this is for the Mk5 diesel Transit with the 3 terminal alternator and mechanical speedo.
Tools Needed.
Phillips screwdriver
T 20 torx Driver
10mm socket
Spanner for battery Terminal.
Firstly check if you have mechanical or electronic speedo, then source your speedo/rev counter either from a Mk 1 Mondeo diesel or appropriate Transit dash. Try to get the multi plugs at the same time as you will need the white/black wired connector. remove any unwanted lamps ie ABS, Airbag etc.as these are not needed.
1. Dissconect Battery.
2. Remove top and bottom steering colum shroud (2 screws bottom 1 screw top).
3. Remove multi function stalks (lights/ indicators etc) for this you need T20 Torx Driver.
4. Remove the 4 screws that holds surround and remove through top between steering wheel and dash (be careful as it is only plastic and can be a bit fiddly)
5.Remove the 5 screws that hold in the instrument panel.
6. Pull panel forward and remove left hand multi plug then speedo cable then right hand multi plug, then pass the instument panel out of the right hand side between steering wheel and dash.
7. Remove the cover on the large multi plug, this exposes all the connectors the no you need for the rev counter is no 8. Press home the white/black connector in no 8 terminal and connect tail end of this cable to new cable.
8. Pass cable through speedo cable hole and feed round to alternator and secure along route using cable ties.
9. Connect to right hand terminal (no 3) on alternator using a crimp conector. This terminal should already have a white/black cable connected but it only goes to a terminal block next to the battery so dont worry about it.
10. Replace multi plug connectors and speedo cable back onto instrument panel.
11. I now reconected the battery and made sure rev counter worked and all lights worked including illumination lights.
12. Refitting is now just a reversal of the removal.
If you are unable to get the multi plug connectors I have several other different coloured cable ones, ok not the correct colour but not a problem if you e-mail me with your address I will send you one in the post to get you out of trouble. any problems e-mail me and I will see if I can help.
Hope I have explained it ok, and good luck.
PS I did not have to change any other connections and it really is just a direct replacement.
Steve.
steviebee
rev counter
Postby steviebee » Sun May 14, 2006 6:56 pm
Hi Ecosse, the answer is I dont know about the electronic ones although all things are possible I dont see why not. I believe the later Mondeos did have the electronic speedo. Sorry I cant be of any more help on this one perhaps some one else has done this conversion before, but if it was me I would give it a go and see, I will try and pick up a mondeo workshop manual and look at the wiring diagram to see if it sheds some light on it. If it helps I bought the speedo/ rev counter from my local breakers for £20 and I could have had either the mechanical or later electronic one for that price. I hope someone else can throw further light on this one for you
Regards
Steve.
steviebee
Postby 100ps_drw_hicube » Sun May 14, 2006 6:57 pm
nice one.. the connector is the final part on my list for my next visit to scrappy :lol: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby Ecosse » Sun May 14, 2006 7:39 pm
Thanks StevieBee, I'll try and source one from a breakers and give it a try.
Cheers
Alex
Ecosse
Postby OxtonyxO » Sun May 14, 2006 8:01 pm
i had i go at this with the electrionic speedo
got it all working but the rev counter works wrong
it reads 7000 rpm
when it should reads 700 rpm
this was with the later alternator
OxtonyxO
