2002 LWB HI TOP Power loss
Postby Richard_Lloyd1985 » Sat Dec 05, 2009 6:44 pm
Im having trouble with power in my transit. Ive just had the flywheel and clutch changed to a solid single mass and ive cleaned out the EGR valve. Ive also put in a diesel treatment to clean out the fuel lines. Ive just done a oil, oil filter, air filter and diesel filter change and it still takes around 4 miles to get upto 70mph with it empty. Been to ford garage and theres no fault codes comming up on there computer. They were looking at it for 6 hours and couldnt come up with a deffinate answer. Any suggestions? its a 90 T350.
Richard_Lloyd1985
Re: 2002 LWB HI TOP Power loss
Postby ake » Sat Dec 05, 2009 6:45 pm
Have you blanked off the egr :?:
Postby Richard_Lloyd1985 » Sat Dec 05, 2009 6:56 pm
No, been told that it could do more damage than good. Ill attempt it tomorrow. Any other ideas if that fails?
Richard_Lloyd1985
Postby MinorMatt » Sat Dec 05, 2009 7:05 pm
You havent got a binding brake have you?
Postby winterheating » Sat Dec 05, 2009 7:47 pm
Richard_Lloyd1985 wrote:No, been told that it could do more damage than good. Ill attempt it tomorrow. Any other ideas if that fails?
who and for what reason :?:
the solid flywheel will cause more damage.
ford even do a 2.4 engine same power outputs without EGR fitted and its up on torque :!:
winterheating
Postby Richard_Lloyd1985 » Sun Dec 06, 2009 2:59 pm
Thats what ford told me about blanking it off. Im gonna blank it off today and see what happens, if no different ill just put it back. Should i change the injector pump? as i been told its another common problem? Its ok in 1st and 2nd gears upto about 30mph, then sluggish and no power all the way upto my top speed off 70mph! (although i only get to 70mph if the roads longer then 5miles)
Richard_Lloyd1985
Postby DEAN MACHINE » Sun Dec 06, 2009 6:50 pm
Richard_Lloyd1985 wrote:Thats what ford told me about blanking it off. Im gonna blank it off today and see what happens, if no different ill just put it back. Should i change the injector pump? as i been told its another common problem? Its ok in 1st and 2nd gears upto about 30mph, then sluggish and no power all the way upto my top speed off 70mph! (although i only get to 70mph if the roads longer then 5miles)
with that top speed it sounds like you have got a towing axle on it
DEAN MACHINE
Postby Richard_Lloyd1985 » Sun Dec 06, 2009 8:16 pm
theres just no power on it. surely if i went into fords they would off noticed that as they was looking at why it was so slow? plus it pulls away upto 30mph the same as another van. just between 30mph and 70mph its slow. even when its empty.
Richard_Lloyd1985
Postby Richard_Lloyd1985 » Sun Jan 17, 2010 2:28 am
just put back in my ecu after getting it remapped by van tuner and am very pleased with the performance now. well worth the money
Richard_Lloyd1985
