I have a 1987 Ford Transit swb with a 2.5Di engine fitted. The engine is now smoking a bit and obviously worn which may explain why it also seems a bit low on power. It is a 120 model with a four speed box.
I am thinking about changing it for either the same engine or perhaps ideally a later engine assuming the engine mounts and bellhousing etc. marry up. Hence I suppose the question is how easy would it be to fit a later 2.5di with five speed box and how late can I go before the engine mounts etc. and ancillary bits cause grief.
Would anyone be able to advise on the best option and point me in the direction of a dealer who they would recommend for a second hand engine?
Thanks. Ideally I would love to put a Mercedes 310D engine and driveline in it but such is life!!
