door convertion
door convertion
Postby vanman » Sat May 06, 2006 6:26 pm
hiy has any ever changed the back doors on a transit from the double doors to the single lift up door.
how hard is it to do and how do u do it
vanman
Postby MrMPuk » Sat May 06, 2006 6:30 pm
It's a fairly simple job but you need to make sure you get all the bits from the donor van. ie the top hinge plates that mount in the van.
Postby Luke » Sat May 06, 2006 6:33 pm
also be aware that the top hinge has a raised boss on the pillar so that will need cutting out, plating, filling and painting :D
