converting rhd to lhd
Postby cato » Mon Dec 14, 2009 9:33 am
I need to convert an 2001 Transit 350 from rhd to lhd , can anyone offer advice or assistance. I am in Spain.
Please dont suggest buying a lhd drive as in this instance it is not the practical thing to do.
Thanks in advance
cato
Re: converting rhd to lhd
Postby MinorMatt » Mon Dec 14, 2009 12:03 pm
I would suggest its not a practical thing to do (though I suspect its possible) and in reality you would probably need a LHD donor for it to be financially viable
I would either suggest living with RHD or searching for a LHD (even though you say its not practical)
Postby AlanN » Mon Dec 14, 2009 1:23 pm
agreed
Postby bazw » Mon Dec 14, 2009 3:30 pm
off top of head and in no way full list but
dash
steering column
rack
pedal box
wiring harness
maybe back plate pedal box mounts to and fill plate for old drivers side
does the gear change move to the left too ? !!! i dont know but bet it would so floor may need changing
seats
mirrors will need to be done too
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby GBBiker » Mon Dec 14, 2009 6:01 pm
Just out of interest, why do you need to change the drive side?
You would not believe the number of LHD vehicles here in the UK.
GBBiker
Wrong Again!
Postby bazw » Mon Dec 14, 2009 6:28 pm
disregard miss read lol
maybe so it has some resale value !!?
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby FATBOYFIN » Mon Dec 14, 2009 7:24 pm
fuel filter as to be moved to the other side as as its in the way of were you will need to put the brake servo, the gear leaver will have to be moved to make it lean towards the drivers side
FATBOYFIN
Postby AlanN » Tue Dec 15, 2009 10:41 am
I was going to say move brake lines to other side...
Postby ake » Sat Dec 19, 2009 8:00 pm
Headlights will need to be changed
Postby Trojan » Sun Dec 20, 2009 12:43 am
If you want it to be registered as a Spanish van, you just need to fit LHD headlights to it, then it should be OK (as long as it passes their tests etc).
Some people say I am stupid... I never realised I was that clever.
Trojan
Postby FATBOYFIN » Sun Dec 20, 2009 11:35 am
you cannot register a rhd van in spain unless you have 360 degree vision ie side windows they wont even let you register a rhd pickup just in case you put a box on the back and lose the all round vision.
FATBOYFIN
Postby Trojan » Sun Dec 20, 2009 1:40 pm
FATBOYFIN wrote:you cannot register a rhd van in spain unless you have 360 degree vision ie side windows they wont even let you register a rhd pickup just in case you put a box on the back and lose the all round vision.
Yikes, really? Hmm - that stuffs up my plan then :(
Trojan
