VALIANT GAS WATER HEATER INFO
Postby wildcamper » Mon May 08, 2006 11:02 pm
MY TRANSIT CI CAMPER HAS A VALIANT GAS WATER HEATER AND I CAN NOT GET IT TO WORK.
THE GUY I GOT THE CAMPER OFF SAID HE NEVER USED IT IN THE 2 YEARS HE HAD THE CAMPER ANY IDEAS GUYS :!:
Gwilym
wildcamper
Postby pippadee » Tue May 09, 2006 9:59 pm
Hi, our travelhome has one of those which even tho we got it working it doesn't really heat enough water for anything useful. We checked we were getting a spark and then took the small ceramic jet out. You will need a very fine strand of wire to clean the jet. Also check that you are getting gas out of the jet. We do have a set of instructions for it for lighting etc.
Is yours a ci travelhome? Does it have twin rear wheels as the motorhome only had single? Ours is on the past featured van page if you want to compare.
pippadee
Postby gemini » Tue May 09, 2006 11:19 pm
pippadee wrote:Hi, our travelhome has one of those which even tho we got it working it doesn't really heat enough water for anything useful. .
it cant be working right because they will run a shower no problem
gemini
Postby pippadee » Wed May 10, 2006 11:22 am
It does heat water but only enough for a hand wash. We think its probably furred up inside but not sure how to go about cleaning it and can't seem to find any spares. If you know more then please enlighten us.
pippadee
Postby MrMPuk » Wed May 10, 2006 2:24 pm
Rather than running water through it try some descale solution, that should do the job.
Postby gemini » Wed May 10, 2006 4:40 pm
caravan shops usually will be able to help you with things like this, sounds like it may be the burners not working at full heat, does it fire up as soon as you turn the tap on??
gemini
Postby pippadee » Wed May 10, 2006 10:40 pm
yep, fires up ok but the water that comes out is only just warm. Thats why we think its the heat exchanger. Plan on trying to take it out and have a proper look. It is 30 yrs old after all!
pippadee
