Swanning_it wrote:Thanks for the feedback guys. Interesting viewpoints.
I'm somewhere in between. I love the Mk 6 I have, but the abnormal amount of time it spends getting repairs is a real downer. I also realise to get the power it delivers out of such a small engine, obviously requires change, hence the reason I asked the question. I see no one has ventured a comment on the solid flywheel conversion. Are these a genuine part or not? If genuine, why not just fit them from the start? It seems that would eliminate the need to replace them (and the starters etc etc).
Mine was replaced at 92000 km under warranty but Ford mentioned that the flywheel alone would have cost me AU$2500 (about 1250 GB pounds). We get ripped off out here usually with spare parts prices, but if this is a regular "maintenance" cost, it seems disproportionately large to me.
Ian
on the genuine conversion its up to you, the way i think of it is solid is ok if the transmission has been built to take the extra abuse that a DMF dampens.
the early FWD 100ps mk6 were fitted with dmf, then they canged the driveshafts, and started fitting solid flywheels
then the RWD's all have DMFs as there built to take more weight and have higher torque output to start with.
if a dmf takes away vibration, its basically sacrificing itself to protect transmission and engine, reducing fuel consumption, and increasing comfort and drivability.
no matter what people say DMFs are actually a good thing and manufactures will continue to fit them when needed.
all makes and models can have clutches fail at silly miles like 12k,
cos of the drivers, if a DMF can go for over 100k then its not a major problem.
i know a taxi firm that have quite a few 0-06 tdci's that have the same DMf flywheel fitted as the 125ps tdci mk6 fwd transit, and they say theyve onl;y had to do a few so far with milage of 200-300k.
also quality parts that ford make like slave cylinders, are a lot more robust than replacement parts, or
FIAT parts.if i needed new concentric slave cylinder, id either get a new ford one or secondhand ford one, but not a pants QH or something.
the question you have to ask yourself is what milage has the original Dmf covered, and would it be acceptable to do that milage again if it was replaced with the correct DMF.
also how has it been driven all its life.
or replace with solid, which is only going to ruel out the flywheel ever failing, but still could have premature clutch failure as more stress be put on the clutch springs and also could be driver fault. also have increased fuel consumption, increased vibrations, more stress on gearbox, engine and drive train.
