connect injection pump pressure HELP !
Postby hts1000 » Wed Dec 30, 2009 10:17 am
Hi Guys
thanks for all your help so far but I have come across another problem with my TDDI
After repairing the head from a cambelt failure I am unable to get the van to fire, It took me 3 hours to get fuel to the injectors, I now have what looks like good flow to the injectors but I have taken out the injectors and there is no fuel coming through them at all.
Any Ideas?, How do I check if the pump is turning on? should I see high pressure at the pipes feeding the injectors?
Any help will be greatly appreciated
cheers
hts1000
Re: connect injection pump pressure HELP !
Postby ake » Wed Dec 30, 2009 10:22 am
yes the pressure should be high at the injectors, they can be a pig to bleed, basically you just keep filling up the filter with diesel, keep crackin injector nuts and keep cawing till she starts,
Postby hts1000 » Wed Dec 30, 2009 10:29 am
Thanks AKE
I have even tried draging it down the road to bleed the system but it still doesnt work, Is there a way I can check the pump is working?
cheers
hts1000
